Making a Rotary Tool
Intro: Making a Rotary Tool
To introduce it all..I've always wanted a Dremel (actually...just for a little while now) in order to do certain projects. So after much toiling, I've devised a way to make one, that will allow you to:
1. Have a fatter wallet
2. Have a greater sense of accomplishment
3. Sand (among other tasks) the hell out of things!
The Rotary tool I'm showing you how to make will have interchangeable tips for it (though I'm only showing you how to make a sander), light weight, and a LOT more fun than a store bought tool could ever be, unless that store bought tool involved lasers, sharks, and spinning blades...but thats for another time.
Before we start: Be careful, nothing here is too dangerous, but they can make you uncomfortable. You could get shocked by the battery since our switch is so "DIY" (Don't use this with higher voltages) though it will just tingle, not injure you. The aluminum can will be sharp when you cut it. So don't rub the sides of it..duh. And of course using a blade of any kind can always be dangerous. Just use common sense, people.
STEP 1: Supplies
Forgive the picture for not having everything you will use, as I added stuff along the way.to fit my ever changing plans.
You will need:
1 Popsicle
1 Cheap toy that has a motor. (Mine is part of a small train from the dollar store. My dog ate the track, leaving me free to think of a use for the motor) For a toy, check the dollar store, or, after a holiday, CVS puts all of its holiday themed stuff on a 75% off sale. You might as well get a $3-5 hobby motor from radio shack if you're going to go buy one though, they will be more powerful.
1 Battery
1 Aluminum can
A small amount of sand paper
Electrical Tape
Wire (your toy may have some that you can scavenge)
Something to cut with
Glue ( I used hot glue)
Possibly pliers to make thing fit how you want them to
A small amount of aluminum foil.
It may seem like a lot, but things like the battery, motor, and wire can all come from one source.
You will need:
1 Popsicle
1 Battery
1 Aluminum can
Electrical Tape
STEP 2: Disassemble
Eat the Popsicle, wash off the stick and dry.
WARNING: POPSICLES CAN CAUSE SEVERE BRAIN FREEZE IF EATEN TOO QUICKLY :P
That is probably the most dangerous step. (>'.')>
Take apart the toy, finding the motor and battery, and if you want to use it (the easiest way) the battery dock. Also scavenge for anything else you may want from the toy (LEDs, speakers, fabric, other motors....)
STEP 3: Attach the Motor and Wires
Tape the motor onto the very end of the stick, and then tape a wire to each of the contacts. (solder it, if you want)
You can also attach the battery dock during this step, just tape it on.
STEP 4: The Switch
First, you need to pick one wire to be permanently attached, tape it onto one of the metal parts that are connected of the cbattery contact closest to the motor. If your battery dock was nice and exposed like mine, this is easy. If not, just find a place you can wrap it around or tape so it's touching one of the contacts. You can put a little bit of aluminum foil in front of the contact and tape the wire to it if you have to.
This is where aluminum foil REALLY comes in handy. You need to rig it so that you can put the wire somewhere touching the battery contact and have it stay, but then move it to turn off the Dremel. For me, this was around the back where some metal came out. I pinched it over the foil. The foil was then rolled over so it could hold the wire. It may be different for you though.
STEP 5: The Tips
For all tips, you'll need a base, this is where the can comes in. Cut out a section of the can, and then cut a small section from that to these specifications:
1. The same length as the motors gear circumference
2. A bit wider than the gears hight.
I know, pretty strict, right?
Now roll the metal around the gear, and glue the ends together, so its a cylinder without bases.
Next, cut out a piece of sand paper, with the same length as the piece of can, and the same hight as the gear. Glue this onto the cylinder.
Once all this dries, slip it onto the gear, and crimp it in a little so it stays on better. Fortunately, these are easy to make, so once your sand paper wears out, you can just make a new one. You could also make other attachments, such as a blade for the end.
STEP 6: You're Done!
Now you have a working rotary tool, sure its not quite as fast or strong as a Dremel, but it works, is fun, and was cheap!
The last picture is what i did to a pen with this, I made a sort of gradient for you to compare the before and after of sanding off the lettering.
75 Comments
logorbit 10 years ago
http://www.logorbit.com/build-log-homemade-rotary-tool-design/
zainuintel 12 years ago
Jimmy Proton 13 years ago
the tech head 13 years ago
maybe two capacitors hooked up in two different directions so it pulses back and forth
beehard44 13 years ago
andyweigl 13 years ago
Mario1 16 years ago
ShampooRobot 15 years ago
hansonsux 14 years ago
DNMEBOY 13 years ago
motadacruz 14 years ago
All i'm missing is a train with a track where a dog can chew on. Dang, also need to get a dog i see.
Well, maybe i got some other old toy around and maybe my brother likes to chew on it.
Anyway, thanks for the instructable!
milsorgen 14 years ago
phant0m_sp00f3ra 14 years ago
_macgyver_ 14 years ago
