Introduction: Making a Small Knitting Loom
This is a simple knitting loom I created out of wire for making cord cozies. A cord cozy is used by some to keep small pets from chewing on cords. I just think they look neat.
Step 1: Materials
No pictures for this step!
What you need is:
- 2 needle nose pliers
- 16 gauge wire
- A ruler
To knit with it later you will need:
- Some yarn
- A small crochet hook
Step 2: Bending
I would suggest a length of 2 feet on the wire. The first step I guess would be to straighten out your wire as much as possible. It doesn't need to be perfect but it's easier to work with when it's straight. Start bending the first bend about an inch and a half in. It doesn't need to be exactly that length. But that's what I went with.
Next just keep bending back and forth to create a zig zag pattern. Try to keep it at even lengths as you bend.
Step 3: Create "Hook" Bends
Next you want to bend little "hooks" on one of the sides. Try to keep them uniform. This works better using both pliers.
Step 4: Make It Circular!
Okay, I apologize for not having a decent picture of how I did this. But it's really not that difficult. Just keep evenly bending each zig-zag in a little bit until it forms a circle. You can probably see by the pic, I also cut off some of the excess wire. When you get it all bent the way you like, cut the excess to line up with the bottom bends.
I first tried taping the two end pieces with some electrical tape, but when I started working with it the tape just got warm and wanted to slide off. It got sticky and gross, so I wouldn't recommend it.
Also, if you look at the last picture, it allows for cords to be shoved through without having to force open the loom you created.
Step 5: KNIT IT UP!
You're done! Now you just need to knit away!
This was made using the "e-wrap" stitch with a small gauge crochet hook and my very own knitting loom.
I didn't know how to do this 'til a couple weeks ago when I watched this video. So it's really not hard to do!
Here's my tutorial on how to use it: https://www.instructables.com/id/Using-PixelanteAnnies-Knitting-Loom/
Have fun!
22 Comments
4 years ago
nice idea
6 years ago
creative
7 years ago
Cool idea.its called ,"i-cord". I made aloom as a kid from a wooden spool & all nails.used large plastic sewing needle toove yarn over nails.
7 years ago on Introduction
very funny a small knitting loom!
8 years ago
Cool
13 years ago on Introduction
human pets chew cords as well. The kind that are several years old and have a lust for destruction. I will definitely make use of this one!
I have a little brother named Silas(he is cute!)he is 6 monthts old and I will make some for my dad.But for now,I just make snakes!
11 years ago on Introduction
you can also use a latch hook for knitting. If you use stiff cardboard, you can make one that way also
12 years ago on Introduction
so i want to make this and try it but i dont get how to start can u help?
Reply 12 years ago on Introduction
There you go!
THIS IS SO CUTE!!! I absolutely love it!!! Not any of of pets chew on my cords or anythings, but I am sure I will end up making one for every cord in the house. just adorable
13 years ago on Step 5
The video is not working
Reply 13 years ago on Step 5
Looks like they updated there site. Not sure if this is the same video, but it should help http://www.decoraccentsinc.com/category_s/95.htm
Nice work on the cord cover, this is definitely a 5/5 project. If you've ever purchased these from a home store or decorator source, you've most likely experienced: the lengths are never a perfect fit, the colors are the most common standardized ones and the manufacturing is shoddy. Btw awesome first Instructable (faved till further use)
14 years ago on Introduction
Looks neat. Which pets tend to chew your cords?
Reply 14 years ago on Introduction
Cats may chew cords also... I am on my 5th pair of headsets due to this. Thank you for the Instructable, it is going to be put to good use. I will foil the feline cord bandits.
rabbits and chinchillas like chewing on cords. I lost my hamster once in my apartment and found her chewing on a playstation cable. =)
My dog did, but stopped when he got zapped a couple of times. He is still alive-that's good.
Sure wish I had seen this before I went out and spent $10 on a spool knitter. What I like best about this is that you can make them in several sizes. I'm thinking that my earbuds could use a cozy like this to keep them from getting tangled in my bag. :-)
Do your cords get cold?
