Introduction: Making a Snare From Paracord
The basic paracord survival snare is a noose tied to a stick that is anchored in the ground. It is designed to trap a small game animal by the neck. This snare trap is ideal for trapping chipmunks, squirrels, and rabbits. I typically use this snare to trap squirrels. I would recommend setting this snare in an area with high squirrel traffic, often by a red or white oak tree. Red and white oak trees shed acorns that squirrels love to consume. Squirrels are high in protein making it a great survival food.
Above is a video of the process if you find that easier to follow...
Paracord
A 1-foot branch, that is also 1 inch in diameter
Two thin twigs that are “Y” shape
A knife
Step 1: Creating the Structure
After finding your trapping location, take your branch that is a foot long and make a point on one end using your knife. This will enable you to anchor the stick into the ground. Then make a circular groove slightly below the other end of the branch. This is where you will be tying your noose to.
Step 2: Making the Snare From Paracord
Take 16 inches of paracord. Take out one of the seven inner strands in the paracord. This will be your noose. Tie a small loop on one end of the paracord strand. Be sure it is very tight. Take the other end of the paracord strand and enter it through the small loop on the other side. You now have your noose. Tie the noose around the groove of the branch. Make sure it is tight.
Step 3: Ready, Set, Trap!
Anchor the branch into the ground, in your trapping location. Be sure it is sturdy. Use your two small “Y” shaped twigs to hold the noose up, so the animal can walk through the noose correctly. You have successfully set up your snare.
The animal will walk through the snare and the noose will tighten as it walks through. This will get you the food you need to survive for additional time. I would recommend have more than one snare trap in use.
