Introduction: Making a Wooden Spatula - Hand Tools Only
In this build I want to prove that you don't need expensive tools to build amazing and useful things.
1/2x3x12 in. hardwood (cherry, ash, oak, etc.)
A hacksaw or a double edge saw
A hammer
A 3/4 in. chisel
A sanding file
50 grit sandpaper
100 grit sandpaper
150 grit sandpaper
220 grit sandpaper
Step 1: Gather Your Supplies (and PPE)
Make sure that you gather your tools and supplies. The supply list is above, but the list is here again:
A hammer
A 3/4 in. chisel
A sanding file
50 grit sandpaper
100 grit sandpaper
150 grit sandpaper
220 grit sandpaper
That is the tools/supply list. If you have PPE, I would recommend wearing it.
Step 2: Getting the Main Shape Cut Out
I first used the hacksaw (you can also use a double edge saw), to cut grooves. Then, I connected the grooves with a hammer and chisel. Shown on the photo, are the pieces that need to be chiseled out. The other photo is an almost finished handle for the spatula.
Step 3: Sanding the Spatula Handle
The photo is me sanding the handle of the spatula. I used many items to get the handle smooth. For example, I used sandpaper, a file, and many more.
When I used sandpaper, I used different grits. Those would be 50 and 100 grits.
Step 4: Making the Spatula Head
Using the coping saw, I made the curved cut at one of the corners of the spatula head. I sanded the rough bits of the head out with 100 and 220 grit sandpaper. I then sanded out the red stuff on the outside of the wood. I did that because I wanted the spatula to have a silky, caramel white color and the red coating could be toxic for use.
Step 5: Sanding the Whole Spatula Down
I sanded the whole spatula down with sandpaper. The photo is almost the same type of sandpaper I used. I sanded the spatula until the spatula was the shape, texture, etc. I wanted it to be. I used 100 grit and up to 220 grit sandpaper.
Step 6: Finishing the Spatula
I need to use a food-grade safe finish, to make my spatula not only usable, but safe. I also don't want it to be cracked or warped, which happens when the wood meets hot water. In this case, I am going to use butcher block conditioner, but you could use tung oil, beeswax, or any other food-safe finish.
Hand Tools Only Challenge
2 Comments
2 years ago
Looks great
Reply 2 years ago
Thank you Rocket radhi
