Introduction: Making the Fastest RC Airplane - SR72 DarkStar
Making the World's Fastest Airplane - The SR-72 Dark Star
This is a very fast RC Plane which we are going to build and fly. It crashed very badly at the end.
Materials needed to Build the Plane:-
- 0.5 inch thickness thermocol
- Glue gun
- Metal wire for control rods
- Black Paint
Electronics Setup:-
- Flysky FS-i6X Transmitter & Receiver
- A2212 2450KV BLDC Motors
- 5045 Propellers
- 40A Electronic Speed Controller
- MG90S Servo Motors
- 11.1V 2200mAh 40C Li-Po Battery
Plan Link: https://drive.google.com/file/d/1qn_4wVq9ASEVnY8onPaYKDEu0ykhGN3b/view?usp=sharing
Step 1: Making the Outline
First, we make the outline of the given plane on 0.5 inch thickness foam.
Step 2: Making the Body
We cut out the parts from the foam.
After that, we join all the parts together using hot glue.
Step 3: Painting
After the airframe is ready, we paint the whole body and also add some details and stickers to give it a more scale and realistic look. The paint I used is a normal black poster color.
Step 4: Making the Control Surfaces
Now we make the control surfaces of the Airplane. This is what controls the plane while it is in the air. There are two control surfaces for this model which are located at the trailing edges of the wings.
The control surfaces this plane uses is called Elevon which is a combination of elevator and ailerons.
Elevon = Elevator + Aileron
We use a small MG90S servo motor to move the surface with the help of a control rod.
Step 5: The Engine
Next up, we have the Engine of the Airplane. Which are two Brushless DC Motors.
These are A2212 2450KV motors.
We install them at the rear end of the plane.
Step 6: Electronic Speed Controllers
Then we install the ESCs which control the speed of BLDC motors.
The two ESCs are wired up in parallel.
Step 7: Propellers
Then we install the propellers.
The propellers used are 5045 props.
They should be opposite in direction to each other so that the spinning motion of the two motors balance each other.
Step 8: Receiver
Now we install the receiver which receives signals from the Transmitter and controls the Movement of the airplane.
The wiring is as follows:-
- CH1 - Left servo
- CH2 - Right servo
- CH3 - ESCs
Step 9: Battery
Next up, we make a mounting for the battery
This is a Lithium Polymer battery which is 2200 mah and 40C, and can deliver a current of 88 Amps.
We install the battery such that it balances the Airplane at its Center of Gravity. The CoG is shown in next steps.
Step 10: Transmitter Setup
The next step is to set the Transmitter to Elevon Settings so that it can control this type of Airplane
A have made a detailed video on how to do this setting
https://youtu.be/fU0cFLLZ7jY
Step 11: Center of Gravity
The CoG is shown here.
The plane should balance perfectly when held from this point.
Step 12: Fly It!
Now its the time to fly the Plane
Step 13: Crash It!
I crashed this plane, accidentally. But no worries. We can make it again!
