Introduction: Mamba Paracord Bracelet
How to make a Mamba Paracord Bracelet, you will need these paracord supplies. 10 feet of paracord, two 5 feet pieces if you want a 2 color paracord bracelet. A Paracord Buckle and a lighter and scissors. This Paracord Project will take about 15 minutes. Learn How to Sell Paracord Bracelets.
Step 1: Mamba Paracord Bracelet - 1
Attach the paracord to the buckles, then measure it on your wrist for size. With the first piece of paracord wrap it around underneath both pieces of paracord, then through the hole, and pull it tight.
Step 2: Mamba Paracord Bracelet - 2
Now with the second piece of paracord, do the same thing, wrap it around both pieces from underneath. Then put in through the hole, then pull it tight.
Step 3: Mamba Paracord Bracelet - 3
Again with the first piece of paracord wrap it around both pieces of paracord, from underneath, then through the hole and pull it tight.
Step 4: Mamba Paracord Bracelet - 4
Continue braiding until you reach the other Paracord buckle, make sure you pull each knot tight.
Step 5: Mamba Paracord Bracelet - 5
Then cut the paracord ends, and melt them. Now you Mamba Paracord Bracelet is complete. See the 9 different Paracord Bracelet Patterns, or more Paracord Projects. Check out the New Paracord Blog.
