Arduino Piano With Manual and 7 Presets Songs
Intro: Arduino Piano With Manual and 7 Presets Songs
Arduino Piano Keyboard interfacing with LCD has 2 mode.
The Manual Mode & The presets mode. I used 7 Pushbutton for a simple 7 keys piano and 1 button for Setup Mode to switch to 7 presets songs.
. Preset mode songs: Click the setup mode button first.
- super mario stage 1
- super mario stage 2
- fur elise
- despacito
- joy to the world
- jingle bells
- star wars
STEP 1: Materials
Materials:
- Arduino UNO ( I used clone of it)
- Breadboard(long)
- 1 LED (any color you want. I used blue)
- 8 - 10k ohms resistor
- 2 - 220 ohms resistor
- 1 Piezo buzzer
- 8- tactile push-button
- Connecting Wires(male to male) -- atleast 40pcs
- 1 LCD 16x2 w/ header pins(i used lcd w/ backlight)
- Potentiometer
STEP 2: Pushbutton Connections
Pushbutton has 4 pins. By default(Button is not pressed) A & B are connected , C & D are also connected. So if the button is pressed ABCD are all connected.
1.) Connect Pin D of the Pushbutton w/ a 10 kilo ohms resistor(Doesn't matter which leg cause resistor has no polarity). The other leg of the resistor is connected to Ground(GND) of the Arduino.
2.) Connect Pin B of the Pushbutton to 5 volts(5V) of the Arduino.
3.) Connect Pin C of the Pushbutton to pins of the Arduino (2,3,4,5,6,7,A0, A1).
STEP 3: LED Connections
Light emitting Diode (LED) has a polarity, the Anode leg which is the positive & the Cathode leg which is the negative. The brightness of LED depends on what resistor you use. I used 220 ohms.
1.) Connect the Anode leg or the longer leg of the LED to a 220 ohms resistor.
2.) Connect the other leg of the resistor to the Pins of the Arduino(A5).
3.) Connect the Cathode leg of the LED to Ground(GND).
STEP 4: Piezobuzzer Connections
The buzzer has two leg. Look for the + mark and that is the positive leg.
- Connect the positive leg to Arduino pin A2.
- Connect the other leg to Ground.
STEP 5: Liquid Crystal Display & Potentiometer Connections
LCD to Arduino Connections
- VSS --> GND
- VDD --> 5v
- VO(Dispaly Contrast pin) --> Middle leg of potentiometer
- RS(Register Select) --> Arduino D8
- R/W(Read/ Write) --> GND
- E(Enable) --> Arduino D9
- D0 --> not connected
- D1 --> not connected
- D2 --> not connected
- D3 --> not connected
- D4 --> Arduino D10
- D5 --> Arduino D11
- D6 --> Arduino D12
- D7 --> Arduino D13
- A -->200 ohms resistor to 5v
- K --> GND
STEP 6: Schematic Diagram
STEP 7: Program Code :)
<p>link: https://create.arduino.cc/editor/EngrPanda/a77e4711-b034-430a-92dd-894218e9e007/preview</p><p>#define NOTE_C 262<br>#define NOTE_D 294 #define NOTE_E 330 #define NOTE_F 349 #define NOTE_G 392 #define NOTE_A 440 #define NOTE_B 493</p><p>#include <LiquidCrystal.h></p><p> const int rs = 8, en = 9, d4 = 10, d5 = 11, d6 = 12, d7 = 13; LiquidCrystal lcd(rs, en, d4, d5, d6, d7);</p><p>//////despacito////</p><p>int noteDuration; int pauseBetweenNotes = 0; int negra; //////////////////STAR WARS////////// const int c = 261; const int d = 294; const int e = 329; const int f = 349; const int g = 391; const int gS = 415; const int a = 440; const int aS = 455; const int b = 466; const int cH = 523; const int cSH = 554; const int dH = 587; const int dSH = 622; const int eH = 659; const int fH = 698; const int fSH = 740; const int gH = 784; const int gSH = 830; const int aH = 880; int counter = 0; //////////////////////////////////// #define NOTE_B0 31 #define NOTE_C1 33 #define NOTE_CS1 35 #define NOTE_D1 37 #define NOTE_DS1 39 #define NOTE_E1 41 #define NOTE_F1 44 #define NOTE_FS1 46 #define NOTE_G1 49 #define NOTE_GS1 52 #define NOTE_A1 55 #define NOTE_AS1 58 #define NOTE_B1 62 #define NOTE_C2 65 #define NOTE_CS2 69 #define NOTE_D2 73 #define NOTE_DS2 78 #define NOTE_E2 82 #define NOTE_F2 87 #define NOTE_FS2 93 #define NOTE_G2 98 #define NOTE_GS2 104 #define NOTE_A2 110 #define NOTE_AS2 117 #define NOTE_B2 123 #define NOTE_C3 131 #define NOTE_CS3 139 #define NOTE_D3 147 #define NOTE_DS3 156 #define NOTE_E3 165 #define NOTE_F3 175 #define NOTE_FS3 185 #define NOTE_G3 196 #define NOTE_GS3 208 #define NOTE_A3 220 #define NOTE_AS3 233 #define NOTE_B3 247 #define NOTE_C4 262 #define NOTE_CS4 277 #define NOTE_D4 294 #define NOTE_DS4 311 #define NOTE_E4 330 #define NOTE_F4 349 #define NOTE_FS4 370 #define NOTE_G4 392 #define NOTE_GS4 415 #define NOTE_A4 440 #define NOTE_AS4 466 #define NOTE_B4 494 #define NOTE_C5 523 #define NOTE_CS5 554 #define NOTE_D5 587 #define NOTE_DS5 622 #define NOTE_E5 659 #define NOTE_F5 698 #define NOTE_FS5 740 #define NOTE_G5 784 #define NOTE_GS5 831 #define NOTE_A5 880 #define NOTE_AS5 932 #define NOTE_B5 988 #define NOTE_C6 1047 #define NOTE_CS6 1109 #define NOTE_D6 1175 #define NOTE_DS6 1245 #define NOTE_E6 1319 #define NOTE_F6 1397 #define NOTE_FS6 1480 #define NOTE_G6 1568 #define NOTE_GS6 1661 #define NOTE_A6 1760 #define NOTE_AS6 1865 #define NOTE_B6 1976 #define NOTE_C7 2093 #define NOTE_CS7 2217 #define NOTE_D7 2349 #define NOTE_DS7 2489 #define NOTE_E7 2637 #define NOTE_F7 2794 #define NOTE_FS7 2960 #define NOTE_G7 3136 #define NOTE_GS7 3322 #define NOTE_A7 3520 #define NOTE_AS7 3729 #define NOTE_B7 3951 #define NOTE_C8 4186 #define NOTE_CS8 4435 #define NOTE_D8 4699 #define NOTE_DS8 4978</p><p>///////////////////////MARIO/////////////////////// #define melodyPin PIEZO //Mario main theme melody int melody[] = { NOTE_E7, NOTE_E7, 0, NOTE_E7, 0, NOTE_C7, NOTE_E7, 0, NOTE_G7, 0, 0, 0, NOTE_G6, 0, 0, 0, NOTE_C7, 0, 0, NOTE_G6, 0, 0, NOTE_E6, 0, 0, NOTE_A6, 0, NOTE_B6, 0, NOTE_AS6, NOTE_A6, 0, NOTE_G6, NOTE_E7, NOTE_G7, NOTE_A7, 0, NOTE_F7, NOTE_G7, 0, NOTE_E7, 0, NOTE_C7, NOTE_D7, NOTE_B6, 0, 0, NOTE_C7, 0, 0, NOTE_G6, 0, 0, NOTE_E6, 0, 0, NOTE_A6, 0, NOTE_B6, 0, NOTE_AS6, NOTE_A6, 0, NOTE_G6, NOTE_E7, NOTE_G7, NOTE_A7, 0, NOTE_F7, NOTE_G7, 0, NOTE_E7, 0, NOTE_C7, NOTE_D7, NOTE_B6, 0, 0 }; //Mario main them tempo int tempo[] = { 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 9, 9, 9, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 9, 9, 9, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, }; //Underworld melody int underworld_melody[] = { NOTE_C4, NOTE_C5, NOTE_A3, NOTE_A4, NOTE_AS3, NOTE_AS4, 0, 0, NOTE_C4, NOTE_C5, NOTE_A3, NOTE_A4, NOTE_AS3, NOTE_AS4, 0, 0, NOTE_F3, NOTE_F4, NOTE_D3, NOTE_D4, NOTE_DS3, NOTE_DS4, 0, 0, NOTE_F3, NOTE_F4, NOTE_D3, NOTE_D4, NOTE_DS3, NOTE_DS4, 0, 0, NOTE_DS4, NOTE_CS4, NOTE_D4, NOTE_CS4, NOTE_DS4, NOTE_DS4, NOTE_GS3, NOTE_G3, NOTE_CS4, NOTE_C4, NOTE_FS4, NOTE_F4, NOTE_E3, NOTE_AS4, NOTE_A4, NOTE_GS4, NOTE_DS4, NOTE_B3, NOTE_AS3, NOTE_A3, NOTE_GS3, 0, 0, 0 }; //Underwolrd tempo int underworld_tempo[] = { 12, 12, 12, 12, 12, 12, 6, 3, 12, 12, 12, 12, 12, 12, 6, 3, 12, 12, 12, 12, 12, 12, 6, 3, 12, 12, 12, 12, 12, 12, 6, 6, 18, 18, 18, 6, 6, 6, 6, 6, 6, 18, 18, 18, 18, 18, 18, 10, 10, 10, 10, 10, 10, 3, 3, 3 }; /////////////////////////////////FUR ELISE///////////////// // Fur Elise --> Melody int melody1[] = { NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_B4, NOTE_D5, NOTE_C5, NOTE_A4, NOTE_C4, NOTE_E4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_GS4, NOTE_B4, NOTE_C5, NOTE_E4, NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_B4, NOTE_D5, NOTE_C5, NOTE_A4, NOTE_C4, NOTE_E4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_C5, NOTE_B4, NOTE_A4, NOTE_B4, NOTE_C5, NOTE_D5, NOTE_E5, NOTE_G4, NOTE_F5, NOTE_E5, NOTE_D5, NOTE_F4, NOTE_E5, NOTE_D5, NOTE_C5, NOTE_E4, NOTE_D5, NOTE_C5, NOTE_B4, NOTE_E4, NOTE_E5, NOTE_E4, NOTE_E5, NOTE_E4, NOTE_E5, NOTE_E4, NOTE_E5, NOTE_DS4, NOTE_E5, NOTE_D4, NOTE_E5, NOTE_DS4, NOTE_E5, NOTE_B4, NOTE_D5, NOTE_C5, NOTE_A4, NOTE_C4, NOTE_E4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_GS4, NOTE_B4, NOTE_C5, NOTE_E4, NOTE_E5, NOTE_DS5,</p><p> NOTE_E5, NOTE_DS5, NOTE_E5, NOTE_B4, NOTE_D5, NOTE_C5, NOTE_A4, NOTE_C4, NOTE_E4, NOTE_A4, NOTE_B4, NOTE_E4, NOTE_C5, NOTE_B4, NOTE_A4, 0, };</p><p>// Main tempo of 'Fur Elise' int tempo1[] = { 9, 9, 9, 9, 9, 9, 9, 9, 3, 9, 9, 9, 3, 9, 9, 9,</p><p> 3, 9, 9, 9, 9, 9, 9, 9, 9, 9, 3, 9, 9, 9, 3, 9,</p><p> 9, 9, 3, 9, 9, 9, 3, 9, 9, 9, 3, 9, 9, 9, 3, 9,</p><p> 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9, 9,</p><p> 9, 9, 9, 9, 3, 9, 9, 9, 3, 9, 9, 9, 3, 9, 9, 9,</p><p> 9, 9, 9, 9, 9, 9, 3, 9, 9, 9, 3, 8, 8, 8, 1, 9, }; ////////////////////////////////////// const int BUTTON_C = 2; const int BUTTON_D = 3; const int BUTTON_E = 4; const int BUTTON_F = 5; const int BUTTON_G = 6; const int BUTTON_A = 7; const int BUTTON_B = A0; const int PB = A1; const int LEDBLUE = A5; int buttonStateC = 0; // variable for reading the pushbutton status int buttonStateD = 0; // variable for reading the pushbutton status int buttonStateE = 0; // variable for reading the pushbutton status int buttonStateF = 0; // variable for reading the pushbutton status int buttonStateG = 0; // variable for reading the pushbutton status int buttonStateA = 0; // variable for reading the pushbutton status int buttonStateB = 0; // variable for reading the pushbutton status</p><p>int var1=0; int var2=0; int var3=0; int var4=0; int var5=0; int var6=0; int var7=0; int VAR1=0; const int PIEZO = A2; void setup() { pinMode(BUTTON_C, INPUT); pinMode(BUTTON_D, INPUT); pinMode(BUTTON_E, INPUT); pinMode(BUTTON_F, INPUT); pinMode(BUTTON_G, INPUT); pinMode(BUTTON_A, INPUT); pinMode(BUTTON_B, INPUT); pinMode(PB, INPUT); pinMode(LEDBLUE, OUTPUT); lcd.begin(16, 2); pinMode(PIEZO, OUTPUT);//buzzer negra=640; }</p><p>void loop() { int push= digitalRead(PB);</p><p>if (push==HIGH) { lcd.setCursor(0, 0); lcd.print("1SM 2SM 3ELI 4DES"); lcd.setCursor(0, 1); lcd.print("5JOY 6JING 7S TAR"); VAR1=VAR1+1; delay(300); }</p><p> if (VAR1 == 1) { presets(); digitalWrite(LEDBLUE, HIGH); } else { manualpiano(); digitalWrite(LEDBLUE, LOW); VAR1=0; } }</p><p>void manualpiano() { buttonStateC = digitalRead(BUTTON_C); buttonStateD = digitalRead(BUTTON_D); buttonStateE = digitalRead(BUTTON_E); buttonStateF = digitalRead(BUTTON_F); buttonStateG = digitalRead(BUTTON_G); buttonStateA = digitalRead(BUTTON_A); buttonStateB = digitalRead(BUTTON_B);</p><p> lcd.setCursor(0, 0); lcd.print("Piano ManualMode"); if (buttonStateC == HIGH) { tone(PIEZO, NOTE_C); lcd.setCursor(0, 1); lcd.print("DO"); lcd.setCursor(15, 1); lcd.print("C"); lcd.setCursor(7, 1); lcd.print("1"); } else if (buttonStateD == HIGH) { tone(PIEZO, NOTE_D); lcd.setCursor(7, 1); lcd.print("2"); lcd.setCursor(0, 1); lcd.print("RE"); lcd.setCursor(15, 1); lcd.print("D"); }</p><p> else if (buttonStateE == HIGH) { tone(PIEZO, NOTE_E); lcd.setCursor(7, 1); lcd.print("3"); lcd.setCursor(0, 1); lcd.print("MI"); lcd.setCursor(15, 1); lcd.print("E"); }</p><p> else if (buttonStateF == HIGH) { tone(PIEZO, NOTE_F); lcd.setCursor(7, 1); lcd.print("4"); lcd.setCursor(0, 1); lcd.print("FA"); lcd.setCursor(15, 1); lcd.print("F"); }</p><p> else if (buttonStateG == HIGH) { tone(PIEZO, NOTE_G); lcd.setCursor(7, 1); lcd.print("5"); lcd.setCursor(0, 1); lcd.print("SO"); lcd.setCursor(15, 1); lcd.print("G"); }</p><p> else if (buttonStateA == HIGH) { tone(PIEZO, NOTE_A); lcd.setCursor(7, 1); lcd.print("6"); lcd.setCursor(0, 1); lcd.print("LA"); lcd.setCursor(15, 1); lcd.print("A"); }</p><p> else if (buttonStateB == HIGH) { tone(PIEZO, NOTE_B); lcd.setCursor(7, 1); lcd.print("7"); lcd.setCursor(0, 1); lcd.print("TI"); lcd.setCursor(15, 1); lcd.print("B"); } else { noTone(PIEZO); } }</p><p>void presets() { buttonStateC = digitalRead(BUTTON_C); buttonStateD = digitalRead(BUTTON_D); buttonStateE = digitalRead(BUTTON_E); buttonStateF = digitalRead(BUTTON_F); buttonStateG = digitalRead(BUTTON_G); buttonStateA = digitalRead(BUTTON_A); buttonStateB = digitalRead(BUTTON_B);</p><p> if(buttonStateC == HIGH) { var1=1; var2=0; var3=0; var4=0; var5=0; var6=0; var7=0; } if(buttonStateD == HIGH) { var1=0; var2=1; var3=0; var4=0; var5=0; var6=0; var7=0; } if(buttonStateE == HIGH) { var1=0; var2=0; var3=1; var4=0; var5=0; var6=0; var7=0; } if(buttonStateF == HIGH) { var1=0; var2=0; var3=0; var4=1; var5=0; var6=0; var7=0; } if(buttonStateG == HIGH) { var1=0; var2=0; var3=0; var4=0; var5=1; var6=0; var7=0; } if(buttonStateA == HIGH) { var1=0; var2=0; var3=0; var4=0; var5=0; var6=1; var7=0; } if(buttonStateB == HIGH) { var1=0; var2=0; var3=0; var4=0; var5=0; var6=0; var7=1; } </p><p> if (var1 == 1) { for(var1 = 0; var1 >= var1; var1++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("Super Mario!!!!"); sing(1); var1 = 0; if(var1 == 0){ noTone(PIEZO); delay(100); break; } } } else if (var2 == 1) { for(var2 = 0; var2 >= var2; var2++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("SuperMario2!!!!"); sing(2); var2 = 0; if(var2 == 0){ noTone(PIEZO); delay(100); break; } } } else if (var3 == 1) { for(var3 = 0; var3 >= var3; var3++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("Elise!!!!!!!"); elise(1); var3 = 0; if(var3 == 0){ noTone(PIEZO); delay(100); break; } } } else if (var4 == 1) { for(var4 = 0; var4 >= var4; var4++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("Despacito!!!!!"); despacito(); var4 = 0; if(var4 == 0){ noTone(PIEZO); delay(100); break; } } }</p><p> else if (var5 == 1) { for(var5 = 0; var5 >= var5; var5++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("Joy_to_the_World!"); Joy_to_the_World(); var5 = 0; if(var5 == 0){ noTone(PIEZO); delay(100); break; } } } else if (var6 == 1) { for(var6 = 0; var6 >= var6; var6++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!!"); lcd.setCursor(0, 1); lcd.print("Jingle_Bells!!!"); Jingle_Bells(); var6 = 0; if(var6 == 0){ noTone(PIEZO); delay(100); break; } } } else if (var7 == 1) { for(var7 = 0; var7 >= var7; var7++){ lcd.setCursor(0, 0); lcd.print("Now Playing!!!!"); lcd.setCursor(0, 1); lcd.print("starwars!!!!!"); starwars(); var7 = 0; if(var7 == 0){ noTone(PIEZO); delay(100); break; } } } else { noTone(PIEZO); } }</p><p> ///////////////////////MARIO/////////////////////// int song = 0; void sing(int s) { // iterate over the notes of the melody: song = s; if (song == 2) { Serial.println(" 'Underworld Theme'"); int size = sizeof(underworld_melody) / sizeof(int); for (int thisNote = 0; thisNote < size; thisNote++) { // to calculate the note duration, take one second // divided by the note type. //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc. int noteDuration = 1000 / underworld_tempo[thisNote]; buzz(melodyPin, underworld_melody[thisNote], noteDuration); // to distinguish the notes, set a minimum time between them. // the note's duration + 30% seems to work well: int pauseBetweenNotes = noteDuration * 1.30; delay(pauseBetweenNotes); // stop the tone playing: buzz(melodyPin, 0, noteDuration); } } else { Serial.println(" 'Mario Theme'"); int size = sizeof(melody) / sizeof(int); for (int thisNote = 0; thisNote < size; thisNote++) { // to calculate the note duration, take one second // divided by the note type. //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc. int noteDuration = 1000 / tempo[thisNote]; buzz(melodyPin, melody[thisNote], noteDuration); // to distinguish the notes, set a minimum time between them. // the note's duration + 30% seems to work well: int pauseBetweenNotes = noteDuration * 1.30; delay(pauseBetweenNotes); // stop the tone playing: buzz(melodyPin, 0, noteDuration); } } } /////////////////////FUR ELISE/////////////// int fur = 0; void elise(int s) { fur = s; if (fur == 1){ Serial.println("'Fur Elise'"); int size = sizeof(melody) / sizeof(int); for (int thisNote = 0; thisNote < size; thisNote++) { int noteDuration = 1000 / tempo1[thisNote]; buzz(melodyPin, melody1[thisNote], noteDuration); int pauseBetweenNotes = noteDuration * 1.30; delay(pauseBetweenNotes); buzz(melodyPin, 0, noteDuration); } } } ////////////////////FUR ELISE///////////// void buzz(int targetPin, long frequency, long length) { long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions //// 1 second's worth of microseconds, divided by the frequency, then split in half since //// there are two phases to each cycle long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing //// multiply frequency, which is really cycles per second, by the number of seconds to //// get the total number of cycles to produce for (long i = 0; i < numCycles; i++) { // for the calculated length of time... digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphram delayMicroseconds(delayValue); // wait for the calculated delay value digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphram delayMicroseconds(delayValue); // wait again or the calculated delay value } }</p><p>//////////////DESPACITO/////// void despacito(){ notars(negra, NOTE_D5); notars(negra, NOTE_CS5); // (1) notars(negra/2, NOTE_B4); notars(negra/4, NOTE_FS4); // (2) delay(negra/4); // (3) notars(negra/4, NOTE_FS4); notars(negra/4, NOTE_FS4); // (4) notars(negra/4, NOTE_FS4); notars(negra/4, NOTE_FS4); // (1) notars(negra/4, NOTE_FS4);</p><p> notars(negra/4, NOTE_B4); notars(negra/4, NOTE_B4); // (2) notars(negra/4, NOTE_B4); // (3) notars(negra/2, NOTE_B4); // (4) </p><p> notars(negra/4, NOTE_A4); notars(negra/4, NOTE_B4); // (1) delay(negra/4); delay(negra/4); notars(negra/4, NOTE_G4); // (2) delay(negra/4); // (3) //...... notars(negra/4, NOTE_G4); notars(negra/4, NOTE_G4); // (4) notars(negra/4, NOTE_G4); notars(negra/4, NOTE_G4); // (1) notars(negra/4, NOTE_G4); </p><p> notars(negra/4, NOTE_B4); notars(negra/4, NOTE_B4); // (2) notars(negra/4, NOTE_B4); // (3) notars(negra/2, NOTE_B4); // (4) notars(negra/4, NOTE_CS5); notars(negra/4, NOTE_D5); // (1) delay(negra/4); delay(negra/4); notars(negra/4, NOTE_A4); // (2) delay(negra/4); // (3) notars(negra/4, NOTE_A4); notars(negra/4, NOTE_A4); // (4) notars(negra/4, NOTE_A4); notars(negra/4, NOTE_A4); // (1) notars(negra/4, NOTE_D5); notars(negra/4, NOTE_CS5); notars(negra/4, NOTE_D5); // (2) notars(negra/4, NOTE_CS5); // (3) notars(negra/2, NOTE_D5); // (4) // notars(negra/4, NOTE_E5); notars_jai(negra/2, NOTE_E5,negra/4); // (1) // notars(negra/2, NOTE_E5); </p><p> //----------------------------------------------- tone(PIEZO,NOTE_CS5 ,negra*3/4); //----------------------------------------------- delay(negra/4); delay(negra/4); // (2) delay(negra/4); // (3) noTone(PIEZO); delay(negra/4); //-------------- delay(negra/4); // (4) </p><p> delay(negra/4); delay(negra/4); } void notars(int noteDuration,int LaNota ){</p><p> //noteDuration=negra/4; tone(PIEZO,LaNota ,noteDuration*0.9); // pauseBetweenNotes = noteDuration * 1.30; pauseBetweenNotes = noteDuration * 1.1; delay(pauseBetweenNotes); noTone(PIEZO); </p><p>} void notars_jai(int noteDuration,int LaNota ,int Desfase){</p><p> //noteDuration=negra/4; tone(PIEZO,LaNota ,noteDuration*0.9); // pauseBetweenNotes = noteDuration * 1.30; pauseBetweenNotes = noteDuration * 1.1; delay(Desfase); delay(pauseBetweenNotes-Desfase); noTone(PIEZO); </p><p>} ////////////////////////////////STAR WARS/////////// void beep(int note, int duration) { //Play tone on PIEZO tone(PIEZO, note, duration); //Play different LED depending on value of 'counter' if(counter % 2 == 0) { digitalWrite(LED1, HIGH); digitalWrite(LED2, HIGH); digitalWrite(LED3, HIGH); digitalWrite(LED4, HIGH); delay(duration); digitalWrite(LED1, LOW); digitalWrite(LED2, LOW); digitalWrite(LED3, LOW); digitalWrite(LED4, LOW); }else { digitalWrite(LED5, HIGH); digitalWrite(LED6, HIGH); digitalWrite(LED7, HIGH); delay(duration); digitalWrite(LED5, LOW); digitalWrite(LED6, LOW); digitalWrite(LED7, LOW); } //Stop tone on PIEZO noTone(PIEZO); delay(50); //Increment counter counter++; } void firstSection() { beep(a, 500); beep(a, 500); beep(a, 500); beep(f, 350); beep(cH, 150); beep(a, 500); beep(f, 350); beep(cH, 150); beep(a, 650); delay(500); beep(eH, 500); beep(eH, 500); beep(eH, 500); beep(fH, 350); beep(cH, 150); beep(gS, 500); beep(f, 350); beep(cH, 150); beep(a, 650); delay(500); } void secondSection() { beep(aH, 500); beep(a, 300); beep(a, 150); beep(aH, 500); beep(gSH, 325); beep(gH, 175); beep(fSH, 125); beep(fH, 125); beep(fSH, 250); delay(325); beep(aS, 250); beep(dSH, 500); beep(dH, 325); beep(cSH, 175); beep(cH, 125); beep(b, 125); beep(cH, 250); delay(350); } ////////////////////////////////////////JINGLE BELL///// void Jingle_Bells() {</p><p> tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 293, 562.5); delay(625.0); tone(PIEZO, 293, 93.75); delay(104.166666667); tone(PIEZO, 293, 93.75); delay(104.166666667); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 329, 750.0); delay(833.333333333); tone(PIEZO, 329, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 369, 750.0); delay(833.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 293, 750.0); delay(833.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 329, 656.25); delay(729.166666667); tone(PIEZO, 329, 93.75); delay(104.166666667); tone(PIEZO, 329, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 659, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 375.0); delay(416.666666667); tone(PIEZO, 587, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 391, 281.25); delay(312.5); tone(PIEZO, 440, 93.75); delay(104.166666667); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 281.25); delay(312.5); tone(PIEZO, 523, 93.75); delay(104.166666667); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 375.0); delay(416.666666667); tone(PIEZO, 587, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 391, 281.25); delay(312.5); tone(PIEZO, 440, 93.75); delay(104.166666667); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 281.25); delay(312.5); tone(PIEZO, 523, 93.75); delay(104.166666667); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 375.0); delay(416.666666667); tone(PIEZO, 783, 187.5); delay(208.333333333); delay(208.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 293, 562.5); delay(625.0); tone(PIEZO, 293, 93.75); delay(104.166666667); tone(PIEZO, 293, 93.75); delay(104.166666667); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 329, 750.0); delay(833.333333333); tone(PIEZO, 329, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 369, 750.0); delay(833.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 293, 750.0); delay(833.333333333); tone(PIEZO, 293, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 187.5); delay(208.333333333); tone(PIEZO, 329, 656.25); delay(729.166666667); tone(PIEZO, 329, 93.75); delay(104.166666667); tone(PIEZO, 329, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 659, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 375.0); delay(416.666666667); tone(PIEZO, 587, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 391, 281.25); delay(312.5); tone(PIEZO, 440, 93.75); delay(104.166666667); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 281.25); delay(312.5); tone(PIEZO, 523, 93.75); delay(104.166666667); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 440, 375.0); delay(416.666666667); tone(PIEZO, 587, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 375.0); delay(416.666666667); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 391, 281.25); delay(312.5); tone(PIEZO, 440, 93.75); delay(104.166666667); tone(PIEZO, 493, 750.0); delay(833.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 523, 281.25); delay(312.5); tone(PIEZO, 523, 93.75); delay(104.166666667); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 187.5); delay(208.333333333); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 493, 93.75); delay(104.166666667); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 587, 187.5); delay(208.333333333); tone(PIEZO, 523, 187.5); delay(208.333333333); tone(PIEZO, 440, 187.5); delay(208.333333333); tone(PIEZO, 391, 375.0); delay(416.666666667); tone(PIEZO, 783, 187.5); delay(208.333333333); } //////////////////////JOY TO THE WORLD////////////// void Joy_to_the_World() {</p><p> // tone(PIEZO, 587, 450.0); delay(500.0); tone(PIEZO, 554, 337.5); delay(375.0); // tone(PIEZO, 493, 112.5); delay(125.0);</p><p> tone(PIEZO, 440, 675.0); delay(750.0); // // tone(PIEZO, 391, 225.0); delay(250.0); tone(PIEZO, 369, 450.0); delay(500.0); // // tone(PIEZO, 329, 450.0); delay(500.0); tone(PIEZO, 293, 675.0); delay(750.0); // tone(PIEZO, 440, 225.0); delay(250.0); // tone(PIEZO, 493, 670.3125); delay(744.791666667); delay(5.20833333333); // // tone(PIEZO, 493, 225.0); delay(250.0); tone(PIEZO, 554, 670.3125); delay(744.791666667); delay(5.20833333333); // // tone(PIEZO, 554, 225.0); delay(250.0); tone(PIEZO, 587, 670.3125); delay(744.791666667); delay(5.20833333333); // // tone(PIEZO, 587, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 587, 225.0); delay(250.0); // // tone(PIEZO, 554, 225.0); delay(250.0); tone(PIEZO, 493, 225.0); delay(250.0); // // tone(PIEZO, 440, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 440, 337.5); delay(375.0); // // tone(PIEZO, 391, 112.5); delay(125.0); tone(PIEZO, 369, 225.0); delay(250.0); tone(PIEZO, 587, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 587, 225.0); delay(250.0); tone(PIEZO, 554, 225.0); delay(250.0); // // tone(PIEZO, 493, 225.0); delay(250.0); tone(PIEZO, 440, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 440, 337.5); // delay(375.0); // tone(PIEZO, 391, 112.5); delay(125.0); tone(PIEZO, 369, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 369, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 369, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 369, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 369, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 369, 112.5); delay(125.0); tone(PIEZO, 391, 112.5); delay(125.0); // // tone(PIEZO, 440, 675.0); // delay(750.0); // tone(PIEZO, 391, 112.5); delay(125.0); tone(PIEZO, 369, 112.5); delay(125.0); tone(PIEZO, 329, 220.3125); delay(244.791666667); delay(5.20833333333); // // tone(PIEZO, 329, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 329, 220.3125); delay(244.791666667); delay(5.20833333333); tone(PIEZO, 329, 112.5); delay(125.0); tone(PIEZO, 369, 112.5); delay(125.0); // // tone(PIEZO, 391, 675.0); // delay(750.0); // tone(PIEZO, 369, 112.5); delay(125.0); tone(PIEZO, 329, 112.5); delay(125.0); tone(PIEZO, 293, 225.0); delay(250.0); // // tone(PIEZO, 587, 450.0); delay(500.0); tone(PIEZO, 493, 225.0); delay(250.0); // // tone(PIEZO, 440, 337.5); delay(375.0); tone(PIEZO, 391, 112.5); delay(125.0); // // tone(PIEZO, 369, 225.0); delay(250.0); tone(PIEZO, 391, 225.0); delay(250.0); // // tone(PIEZO, 369, 450.0); delay(500.0); // // tone(PIEZO, 329, 450.0); // delay(500.0); noTone(PIEZO); } /////////////starwars////// void starwars() { firstSection(); //Play second section secondSection(); //Variant 1 beep(f, 250); beep(gS, 500); beep(f, 350); beep(a, 125); beep(cH, 500); beep(a, 375); beep(cH, 125); beep(eH, 650); delay(500); //Repeat second section secondSection(); //Variant 2 beep(f, 250); beep(gS, 500); beep(f, 375); beep(cH, 125); beep(a, 500); beep(f, 375); beep(cH, 125); beep(a, 650); delay(650); }</p>
Nova Joy M.O 2 years ago
