Introduction: Marble Fidget Necklace
This necklace design I came upon while trying to make something conducive to fidgeting but also beautiful. The marble can be spun in its cage of wire while being worn. It is also very easy to make!
Step 1: Materials and Tools
Materials
-A glass marble, not too big or too small
- About 10-13 inches of easily bendable wire
-A chain
Tools
-Hands
-Something to cut the wire, even regular scissors could work
-Needlenose pliers (Optional but recommended. I do not use them in this tutorial)
Step 2: Bending the Wire Around the Marble
Once you have cut your wire into about 10-13 inches of length, start bending it around your wire. At first the marble will want to pop out. Keep wrapping the wire in one continuous line around the marble, then deviate from that line to better enclose the marble. Make sure to leave some areas un-wrapped with wire so fidgeting is easier. Finish with a loop with which to attach the chain
Step 3: Attach the Chain
This should depend on what chain you have. Just insert it through the loop you made and re-attach the ends. I had to cut my chain because it hung too far down.
Step 4: You're Done!
That is all! Its a pretty simple necklace to make, takes about 5-10 minutes total. Thanks for reading!
