Introduction: Marlinspike Lanyard Knot Whisk Broom
This is ABOK 787. Many of you are familiar with the 2 strand diamond/lanyard knot so this is familiar to you.
It is easier to tie than the "Manrope Knot Whisk Broom."
https://www.instructables.com/id/Manrope-Knot-Whis...
I used 1 1/2' of 5/16" sisal to make this whisk.
Step 1:
Middle your rope and put it over your palm.. This forms the handle loop of the brush.
Step 2:
Make a half hitch with the lower end and place it over the top end.
Step 3:
Bring the top end under the lower end.
Step 4:
And to the left going over, under, over. Tighten on hand.
Step 5:
Take either end (A) and bring it over the handle and through center of knot.
Step 6:
Do the same with the other end (B).
Step 7:
Grab the two ends in one hand and the handle in the other hand and pull apart.
Step 8:
Unlay the two ends into their separate strands.
Step 9:
Separate the strands into their separate fibers.
Step 10:
Comb out the fibers.
Dipping the fibers in water helps take some of the residual twist and helps in the separation process.
