Introduction: Mars Roomba
This Instructable will guide you in the directions of operating a Raspberry Pi controlled Roomba vacuum bot. The operating system we will be using is through MATLAB.
Step 1: Supplies
What you will need to gather in order to carry out this project:
- iRobot's Create2 Roomba vacuum cleaner bot
- Raspberry Pi
- Raspberry Pi Camera
- The latest version of MATLAB
- The Roomba install toolbox for MATLAB
- MATLAB application for a cellular device
Step 2: The Problem Statement
We were tasked to use MATLAB to develop a rover that could be used on Mars in order to assist scientists in gathering planet data. The functions that we addressed in our project were of remote control, object impact recognition, water recognition, life recognition, and image processing. To achieve these feats, we coded using the Roomba toolbox commands to manipulate the many functions of iRobot's Create2 Roomba.
Step 3: Bluetooth Remote Control
This slide will walk-through the code to control the Roomba's movement using the Bluetooth capabilities of your smartphone device. To begin, download the MATLAB application to your smartphone and log in to your Mathworks account. Once logged in, go to "more", "settings", and connect to your computer using its IP address. Once connected, go back to "more" and select "sensors." Tap onto the third sensor on the top toolbar of the screen, and tap onto start. Now, your smartphone is a remote control!
The code is as follows:
while 0 == 0
pause(.5)
PhoneData = M.Orientation;
Azi = PhoneData(1);
Pitch = PhoneData(2);
Side = PhoneData(3);
bumps = r.getBumpers;
if Side>80 || Side<-80
r.stop
r.beep('C,E,G,C^,G,E,C')
break
elseif Side>20 && Side<40
r.turnAngle(-5);
elseif Side>40
r.turnAngle(-25);
elseif Side<-20 && Side>-40
r.turnAngle(5);
elseif Side<-40
r.turnAngle(25);
end
if Pitch >10 && Pitch<35
r.moveDistance(.03)
elseif Pitch>-35 && Pitch<-10
r.moveDistance(-.03)
end
end
Step 4: Impact Recognition
Another function that we implemented was to detect the impact of the Roomba into an object and then correct its current path. To do this, we had to use conditionals with the readings from the bumper sensors to determine if an object was struck. If the robot hits an object, it will back up .2 meters, and rotate at an angle determined by which bumper was struck. Once an item has been hit, a menu pops up displaying the word "oof."
The Code is shown below:
while 0 == 0
r.setDriveVelocity(.1)
if bumps.left == 1
msgbox('Oof!');
r.moveDistance(-0.2)
r.setTurnVelocity(.2)
r.turnAngle(-35)
r.setDriveVelocity(.2)
elseif bumps.front == 1
msgbox('Oof!');
r.turnAngle(90)
elseif bumps.right == 1
msgbox('Oof!');
r.turnAngle(35)
elseif bumps.leftWheelDrop ==1
msgbox('Oof!');
r.turnAngle(-35)
elseif bumps.rightWheelDrop ==1
msgbox('Oof!');
r.turnAngle(35)
end
end
Step 5: Life Recognition
We coded a life recognition system to read the colors of objects in front of it. The three kinds of life that we coded for are plants, water, and aliens. To do this, we coded the sensors to calculate the average values of red, blue, green, or white. These values were compared to the thresholds that were manually set to determine the color that the camera is looking at. The code would also plot the path to the object and creating a map.
t = 10;
i = 0;
while t == 10
img = r.getImage; imshow(img)
pause(0.167)
i = i + 1;
red_mean = mean(mean(img(:,:,1)));
blue_mean = mean(mean(img(:,:,3)));
green_mean = mean(mean(img(:,:,2)));
white_mean = (blue_mean + green_mean + red_mean) / 3; %want this val approx 100
nine_plus_ten = 21;
green_threshold = 125;
blue_threshold = 130;
white_threshold = 124;
red_threshold = 115;
while nine_plus_ten == 21 %green - life
if green_mean > green_threshold && blue_mean < blue_threshold && red_mean < red_threshold
r.moveDistance(-.1)
a = msgbox('possible life source found, location plotted');
pause(2)
delete(a)
[y2,Fs2] =audioread('z_speak2.wav');
sound(y2,Fs2)
pause(2)
%plant = r.getImage; %imshow(plant);
%save('plant_img.mat', plant');
%plot location in green
i = 5;
break
else
nine_plus_ten = 19;
end
end
nine_plus_ten = 21;
while nine_plus_ten == 21 %blue - woder
if blue_mean > blue_threshold && green_mean < green_threshold && white_mean < white_threshold && red_mean < red_threshold
r.moveDistance(-.1)
a = msgbox('a source of water has been found, location plotted');
pause(2)
delete(a)
[y3,Fs3] =audioread('z_speak3.wav');
sound(y3,Fs3);
%woder = r.getImage; %imshow(woder)
%save('water_img.mat',woder)
%plot location in blue
i = 5;
break
else
nine_plus_ten = 19;
end
end
nine_plus_ten = 21;
while nine_plus_ten == 21 %white - aliens monkaS
if white_mean > white_threshold && blue_mean < blue_threshold && green_mean < green_threshold
[y5,Fs5] =audioread('z_speak5.wav');
sound(y5,Fs5);
pause(3)
r.setDriveVelocity(0,.5)
[ys,Fss] =audioread('z_scream.mp3');
sound(ys,Fss);
pause(3)
r.stop
% alien = r.getImage; %imshow(alien);
% save('alien_img.mat', alien);
i = 5;
break
else
nine_plus_ten = 19;
end
end
if i == 5
a = 1; %turns angle
t = 9; %terminate big loop
i = 0;
end
end
Step 6: Run It!!
After all the code has been written, combine it all into one file and voila! Your Roomba bot will now be fully functional and operate as advertised! However, the Bluetooth control should either be in a separate file or separated from the rest of the code with %%.
Enjoy using your robot!!
