Introduction: Mask Apparatus
For this certain apparatus that you are creating there isn't that many supplies that you need for this. First, you need a mask because that's what you will wear and the main piece of the apparatus. Secondly, you need 4 rubber bands that are 3 5/8 inches long or if you don't have a ruler it is most likely the size of your middle finger and the rubber bands are used to add it to the ear strap of the mask. Lastly you need the large binder clip to attach it to the rubber bands on the back
Step 1: Step One
First, you get the rubber bands and the mask out to use and put together
Step 2: Step Two
Then, you get one of the rubber bands and then straighten it out and after loop it around the ear strap of the mask and then you tie the rubber band on the ear strap
Step 3: Step 3
Next, get the other rubber band, straighten it out and loop it around the hole of the rubber band you already tied and then tie up the rubber band together with the other rubber band and go to the other ear strap and repeat the last 3 steps and then the mask should look like the picture above
Step 4: Step Four
After, put the mask on and then get the large binder clip and put it behind your head the start to open up the binder clip
Step 5: Step Four
Get a hole from the second rubber band that you put on from each side and then put it in the opening of the binder clip and then repeat that step for the other side and you are complete
