Mason Jar Shotgun Shell Nightlight
Intro: Mason Jar Shotgun Shell Nightlight
Whether you are a redneck or afraid of the dark this shotgun shell mason jar night light Instructable is just for you!
STEP 1: Supplies Needed
For this bright Instructable your going to need;
1.) Mason Jar
2.) Water
3.) Shotgun Shells
4.) LED battery light (or some other form of light source)
1.) Mason Jar
2.) Water
3.) Shotgun Shells
STEP 2: Packing
First things first. Place as many shotgun shells as possible into the mason jar without overflowing it.
STEP 3: Adding H2O
Next top off the jar with water.
The reason you fill the jar with water is because the water magnifies the contents inside.
STEP 4: Adding the Light
Finally, stick your sticky light to either the side of wall or place it on top so the light can shine down.
STEP 5: All Done!
Boom! Your all done! This can also work with other forms of ammunition!
Have fun, be safe, and God bless!
3 Comments
SugarCluster 9 years ago
Maybe mixing this with lava lamp (mason jar lava lamp, especially) will be enough for this to be more awesome. (Use shells with same color of the wax)
Shells will freely float about and give it some more feelings.
(If you don't like lava lamp, try glitter lamps with low-heat heating element)
Joe Bass 9 years ago
To compensate with the weight of shells, you can fill the inside with hard plastic foam and some bearings so it floats freely while not floating to the surface or sinking into the bottom.
That way you can achieve the "faux aquarium" effect!
