Introduction: Match & Learn
We've made an interactive game for kids destinated to improve their english skills. The game consist about matching the silouette of the animal with it's corresponding name. There are 8 options to choose, a bunch of matches to make and infinity of possibilities!
- Arduino Mega
- Cables
- Led's (x16)
- Joystick device
- Resistors
- DM wood
- White Glue
- Welder
- Tin
- Welding plate
- 5V Battery
- Baking paper
Step 1: Cut the DM Wood in a Laser Machine
We recommend you to cut it in a wood table of 610x450mm and 3mm width.
Step 2: Paint the Outer Pieces
You can use spray and the colour that you prefer!
Step 3: Prepare the Arduino in the Protoboard
Step 4: Copy Your Code Here!
Step 5: Weld the Resistors and the Cables in the Welding Plate
Step 6: Add the Heat Shrink in the Cables
For a cleaner finish.
Step 7: Mount the Pieces; Glue All the Borders With the Inferior Base
The pieces are made to fit the same way as the photo.
Step 8: Glue the Baking Paper Behind the Superior Case
Glue the baking paper with the shape to fit behind the superior case. This gives a translucid layer behind the silouettes.
Step 9: Fix the Joystick Device in the Inner Base
You can glue it or fix it with some screws.
