Introduction: Measure EEG With Arduino
About: Brain Computer Interface researcher
Instructions on how to measure EEG, EMG, and ECG bio-signals with Arduino
Step 1: EEG With Arduino
If you want to measure EEG, EMG, and ECG bio-signals with Arduino, probably it is an easy way. Just need only connect ardEEG shield directly as hat to Arduino board and from this moment Arduino be transferred to Brain-Computer interface.
Easy start. Just only 2 scripts, one for Arduino and one for Python in Windows (etc)
This project is the result of several years of work on the development of BCI. I believe that the easiest way to get started with biosignals is to use a shield.
How it works
Connect the shield to Arduino Uno R4 WiFi and after that connect the device to a battery (power supply) and connect the electrodes.
Electrodes are positioned according to the International 10-20 system ​
Step 2: How to Connect
Device Pinout (Shield connected with Arduino Uno R4 only at the next points and power)
Cables from electrodes are connected directly to the shield as shown in the image
Step 3: Video, How It Works
Video demonstrations in YouTube
Step 4: Where to Use
ardEEG include powerful ADS1299 24 ADC IC. So you can receive good quality and start to use it for projects that you want
Step 5: Biodata
The process of measuring chewing and blinking artifacts using dry electrodes (Fz). Chewing occurred in the following sequence: 4 times, 3 times, 2 times, and 1 time, and the same for the blinking process. The y-axis is the processed EEG signal after passing filter bands of 1-40 Hz in microvolts, and with 250 samples per second
Dataset
Alpha test
The process of recording an EEG signal from an electrode (Fz) with eyes open and closed. The y- axis is the processed EEG signal after passing filter bands of 8- 12Hz in microvolts and with 250 samples per second
Dataset
Step 6: More Information
More information can be found on website
