Introduction: Mechanical CPU Clock
The Mechanical CPU Clock shows the basic building blocks of a CPU (ALU, buses,RAM,registers, and a Control Unit). It executes a set of instructions which will emulate a simple wall clock.
The inspiration for this project came from trying to teach my son and daughter about how a computer works (in reality, I was always fascinated with mechanical computers and clocks, but I had to give a better excuse to my wife for buying a laser cutter specifically for this project). After looking around the web at various mechanical computers, I could not find something that represented all the components of CPU. However, I draw my inspiration from the following projects (and their derivatives):
Marble adding machine: www.youtube.com/watch?v=GcDshWmhF4A
DigicompII: http://digi-compii.com/
Ball Logic: http://brain.wireos.com/?p=2207
In the following sections I will attempt to explain how everything works as it is being built. I am not going to go deep into the subject of computer science and will purposely try to avoid some terms, so to not confuse the novice reader. If I do use any terms, I will try to explain them simply. However, there might be some needed background information that I will miss, so please do not hesitate to contact me about trying to explain the concepts in more details (I don't promise anything, but I will do my best). Even if you are not going to build the clock, going through the sections will help in the understanding of how the clock/CPU works (the build sections will go over the concepts of ALU,RAM,register,control unit and buses). Again, one of the motivations for this project was to get people to understand how a CPU (the heart of a computer) works.
More details about the clock can be found here: http://www.liorelazary.com/index.php?option=com_content&view=article&id=46:mechanical-cpu-clock&catid=10:clocks&Itemid=15
123D: http://www.123dapp.com/idw-3D-Model/Mechanical-CPU-Clock/604647
Step 1: CPU Instructions
For a CPU to do any meaningful work, it needs to be told what to do. This comes in the form of instructions. For this wall clock I will only concentrate on the hours to make things simple. That is, we will increment a variable named Hours and check to see if its equal to 11 (we will use 0 base indexing for the hours, so 12 is represented as a 0). If the check is true, then we will reset the variable back to 0. We do not want to code the above statement directly into the CPU, since we want it to be general purpose CPU (otherwise we are just making a clock). Therefore, we will implement a basic instruction set and write the clock code around these primitive instructions (the set of instructions to execute are known as an assembly language). Lastly, we will keep the hour variable in a Register, which is a term given for a special memory component used to hold data and operate on it. We will also use a simple 1 unit (1 bit) memory address to act as a flag for the control unit, and name it DTD for personal reasons (stands for dedicated to Dani. A long personal story). Note that this CPU will be programed with the clock instructions, but it could be programed with any other code to do a number of other things.
Here are the basic instructions (assembly language) that we will use:
INCRMENT: Increment register A by adding 1 to it.
EQUAL: If register A is equal to a specific number, then skip the next instruction.
CLEAR: set register A to 0, set DTD to false
JUMP: jump to a specific instruction at a given line number
SET_DTD: set DTD to true
CHECK_DTD: if DTD is true, then skip the next instruction.
Here is the assembly language code for the clock (register A will hold the hours).
1: CHECK_DTD
2: JUMP 5
3: CLEAR
4: JUMP 1
5: INCREMENT
6: EQUAL 11
7: JUMP 1
8: SET_DTD
9: JUMP 1
Line 1 checks to see if DTD is set to true (this is used to indicate if we need to reset the hour). If its true the we jump to line 3 and set the hour to 0 and the DTD to false. If DTD is false then we continue with the next instruction and jump to line 5. Line 5 increments the hour (register A), while line 6 check to see if it equal to 11. If register A is equal to 11, then we jump to line 8 and set the DTD to true and jump back to the beginning (line 1). Otherwise, we go to the beginning. If we run though this code once an hour, then by reading register A, we can tell what is the current hour.
Step 2: Hardware Design : Flip-Flop
We will now implement the primitive CPU instructions in hardware and program the CPU. I will use Autodesk Inventor for this mainly because of its great dynamic simulation (www.autodesk.com/Inventor). It also allows for parametric design, which makes modeling a lot simpler.
We start by implementing register A and the ALU (Arithmetic/Logic unit). The ALU is a CPU component that performs all the mathematical operations. In our CPU, the ALU will simply perform a simple operation of adding a 1 to register A. This is also known as an adder (http://en.wikipedia.org/wiki/Adder_%28electronics%29)
Start by creating a 12” diameter disc and attach a Flip-Flop (http://en.wikipedia.org/wiki/Flip-flop_%28electronics%29) to it. A Flip-Flop is a device that alternates its state with a given input. For example, a politician might change his stance on a specific issue based on some event, and then will change it back based on another event. In that case, we say he is a flip-flop, and we might be able to build a computer out of him:) Modern CPUs utilize transistors for their flip-flops, however we will build a mechanical flip-flop that will change its state based on a ball drop.
Step 3: Hardware Design : Register
Next, create a cut in the 12” disk encasing the envelope of the flip-flop, so that the flip-flop can move freely (parametric design makes this process very easy).
Step 4: Hardware Design : Register
Since we want our clock to count up to 12, we will need to represent 11 (0,1,...,11) in our register. Our flip-flop can only have two states, so we can use a binary representation of 11 using 4 flip-flops (1011). We will place the least significant bit (LSB) on top, and the most significant bit at the bottom. We will also create another register (register B) which will hold a copy of register A, and will be used to reset register A to a given number (the CLEAR statement). This will be done by resetting register B and copying the data back to A. Register B will also be 4 bits wide. We can simply do this by making an array of the flip-flop cut.
Step 5: Hardware Design : Register C
Next we will add another register (register C), which will also contain a copy of A. This register will be used for the EQUAL statement to check if register A is equal to 11. We will want to increment and check register A in the same clock cycle (the same ball drop) so we can keep the timing correct. One way to achieve this mechanically will be to place register C under register A, but this will make the clock very long. By examining how the ALU (adder) will work on register A, we can see that the when we change the least significant bit (LSB) to 1, we can escape the register and use the ball to perform the check in register C. Since we are only doing this on the LSB, we can just check the 3 most significant bits (MSB), since we already know that the LSB will be 1. Therefore, we can place register C under and to the left of register A. This can be thought of as code optimization.
Step 6: Hardware Design : DTD
Next we will implement the DTD bit flag (the control unit) in the form of two tracks. If the ball goes on track A, then DTD is false. If its on track B, then DTD is true.
Step 7: Hardware Design : Programming
Programming the clock is achieved by routing the ball to specific locations. That is, we will “hard code” the program into the CPU. The ALU is going to be programmed as an adder, by allowing the ball to continue down register A whenever the flip-flops are at 0, and escaping register A whenever they are 1 (overflow condition). Lastly, we will program the CHECK statement to check for the number 11. As mention before, we are only going to check the 3 MSB (101) so the ball will end up on track B every time this is true, and on track A every time this is false.
Step 8: Hardware Design : Buses
Lastly we will add the bus on our CPU, to connect our registers together. As one of the registers changes, it will copy the data to the rest of the registers.
Step 9: Hardware Design : Code
Here is the final clock with all the appropriate labels. It works by executing the flowing code.
1: CHECK_DTD
2: JUMP 5
3: CLEAR
4: JUMP 1
5: INCREMENT
6: EQUAL 11
7: JUMP 1
8: SET_DTD
9: JUMP 1
Line 1 is at the top of the clock, implemented as a wall. When the ball is on track A, it will hit the wall and drop to register A (line 2). In register A, it will increment the register (line 5) and check to see if register A is equal to 11 (line 6). If the check is false (DTD false) then the ball will end up on track A and the ball gets lifted to the top again (line 7). However, if register A is equal to 11, then the ball will end up on track B (DTD true) and will be lifted up to the top again (line 9). Since the DTD is true this time, the ball will be on track B and pass the CHECK_DTD by moving over to register B. Register B will clear itself to 0 and copy the data via the bus to register A. If will then end up at the bottom on track A (DTD false) and move back up to the top (line 4).
Step 10: Hardware Design : Simulation
Step 11: Hardware Design : Lifter
To lift the ball on track A or B we will use a lever with two magnets and a motor to rotate the lever once an hour. This will allow the ball to drop once every hour and increment register A (which will hold the current hour).
Step 12: Hardware Design : Clock Face
Since we can also read out the current minutes by the position of the lever, we can place the minutes numbers on the clock face just like in a real clock. However, just for fun we will place the minutes in Hex representation instead of decimal.
Step 13: Building the Clock
The piano wire used is 0.5mm which I got from do-it-center as well as the screws (6-32). I got 2.5 inch screws and cut them to length as needed. Other then that, you only need the acrylic. I used 1/2" for the tracks, and 1/8" for the rest (12x12 sheets).
Step 14: Building the Clock
The buses are made out of piano wire. Note the angle band at the top, which will be used to adjust the final length.
Attach the buss wire to the flip-flops by forming an L band at the bottom.
Step 15: Building the Clock
Place the ball inside and attach the face to the backplate and tracks with screws.
Step 16: Building the Clock
The motor used for this clock is a 1 RPH (1 revolution per hour) timing motor, which gets very hot. To dissipate some of the heat, we will base a case for it out of aluminum sheet. Another, more complicated solution, will be top use a stepper motor.
Step 17: Final Clock
Here is the final clock mounted on a wall.
Make It Real Challenge
45 Comments
8 weeks ago on Step 17
What a great learning tool and an awesome outcome... just beautiful.
7 years ago on Introduction
Neat! Very creative.
I want to make one :)
9 years ago on Introduction
What did you use to control the timing and the sweep arm? An existing clock mechanism? Microcontroller?
Thanks
I used a 1RPH motor (I got mine here http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=H1-33&Category_Code=SYNCTIME).
Just plain neat I like it. Looks like fun.
Joe
10 years ago on Introduction
First of all, nice job in implementing this device and showing how it works. Also, congrats on getting the "pass" to buy your laser cutter. ;-)
I think that this is actually a Finite State Machine and NOT a CPU. A CPU fetches instructions from a memory and then takes actions based on those instructions. Actions include jumps within the program counter (PC) space, math operations in the ALU etc.
Your machine includes a set of flip flops representing the "current state". Every time a ball is dropped, the flip flops decide what the "next state" will be based on the "current state" of the machine.
In your description, when you say that your machine is jumping to a line of code, I think you mean that it is jumping to a new binary encoded finite state.
Here is a write up on the differences I found with a quick Google:
http://www.cs.utah.edu/~rajeev/cs3810/slides/3810-14.pdf
Thanks for you comment.
You might be right that its not a CPU, but not because its a Finite State Machine (because a CPU can be boiled down to a FSM). So first you must define what is a CPU (and there are a few), but the view I take is that a CPU is a Universal Turing Machine (UTM). Which state that a UTM is one that can simulate every possible Turing machine (or every possible FSM). There are one instruction set computers (see OSIC) which are able to simulate every possible FSM, and they don't need to fetch instructions, since they only have one.
This clock can be shown to be a Turing Machine, and thus a computer (see fixed-program computers), however, where is its program memory?
I argue that the program memory is implemented in the paths the ball takes, and is burned in using the laser as well as the configurations of the flip-flops, so its similar to burning the program on a ROM. (although I agree this is a far fetch, but remember that the goal of this project was to help explain what's inside a CPU, and not create a CPU to solve various problems). Therefore, I could change the program of the clock (or change the FSM) by simply rotating one of the L levers or changing the T flip-flops to an L. I could also, remake the tracks of the C register, to check for a different number, or change the B register to increment instead of reset (by changing the L to flip-flops and reconfiguring the paths). Also see the Harvard Architecture CPU which has its instructions separated from the data.
However, the main problem is in proving that the instruction set I provided are able to simulate every possible Turing Machine for it to be a CPU (which I don't believe it does). Note that its not that easy, since there are very simple machines which can be a UTM (http://en.wikipedia.org/wiki/Wolfram%27s_2-state_3-symbol_Turing_machine)
However, even if you don't buy the argument that the program is read from memory (and I agree this is hard to swallow, even for me) or that it can not emulate every possible Turing machine. I still stand by the fact that this is still useful in describing a CPU.
Its really stretching it though to say that it is programed though. I can reprogram a finite state machine by slotting in new components too. I feel like the program really should be separated from the processing unit. Reading through it the first time I kept getting confused because you kept referencing lines of code that aren't really in the machine as lines of code. Its a super cool project it just feels like its a little misleading.
I think you have handled the religious discussion on what a CPU is quite well. You are not trying to model a Von Neumann computer (http://en.wikipedia.org/wiki/Von_Neumann_architecture) that so many of us are used to.
My thought is that your son and daughter will learn a lot from your device but are more likely to use their understanding of it to become Electrical Engineers with digital logic design skills (VHDL/Verilog on FPGA/ASICs) than Computer Scientists slinging C or assembly code ;-)
Your implementation of a binary mechanical clock is wonderful.
Either my kids will end up in EE/CS or they will need years of therapy because dad insisted this clock is a computer, but they could never access facebook with it.
In the mean time you can enjoy my 6 year old son trying to explain how to read the clock: http://www.youtube.com/watch?v=iFKargQxN8k
Very c lever and well implemented. Bravo, sir!
Incredible!
Brilliant idea, very very nice execution.
Thanks for the detailed instructable!
This is a really great idea and build!
Also it is a super clear i'ble.
Congrats. This is definately a 5 star project.
www.d-e-f-i-n-i-t-e-l-y.com/
Thanks. But remember that English isn't my mother tongue. It is only my 3th language (of the four that I read, write and speak if you don't count Latin and ancient Greek) and I do make a mistake from time to time. A lot of people aren't even able to write theire own mother tongue properly!
I wil
definately definatly definantly definetly definently defiantlydefinitely remeber it.10 years ago on Introduction
what laser cutter did you buy?
Look on my website. www.liorelazary.com. I wrote a whole article of how I imported the laser cutter from china.
Wow, that's really clever! I understand most of it except how to read the minute hand during the first 25 minutes of the hour before it picks up the ball again. Is it visible through the side of the clock or something?
Sorry, on the video its a bit hard to see, but you can see the shadow of the arm (a bit better in real life). So it is hard to read the minutes from 0 to 25. For my first prototype I used clear acrylic so you saw the arm much better. However, it made the tracks very hard to see. Someone suggested using a semi-clear acrylic (like a fogy one) so you can see the tracks and the arm better.
While I like it, my interpretation leaves 7:15 as the maximum count before resetting to 0:00
