Introduction: MemoryStick Wallet Caddy
After seeing https://www.instructables.com/id/Memory_Card_Caddy and https://www.instructables.com/id/Pipeski_s-Wallet-SD-Holder I decided to make my own caddy taking elements from both instructables but only using credit cards (and some superglue).
What you need...
4 creditcards/giftcards etc
Stanley/craft knife
Superglue
15 minutes
This is my first Instructable so if you make one, can think of an improvement or try this with a different type of memory card please leave a comment!
Blatant plug but the full resolution pictures can be found on my homepage http://michaelwhalen.co.uk
What you need...
Stanley/craft knife
Superglue
15 minutes
Step 1: Measure and Cut the First Card.
You may want to draw round the memory cards, but i was feeling brave so i just cut around the card.
Step 2: Glue the First Card to the Second
I put glue over one side of the cut card in very small stripes and down the prongs in between the cut out parts.
I didn't realize how quickly (instantly) the glue would bond so id advise making sure the cards are lined up perfectly before you press the together hehe, luckily mine were lined up quite well :D
Step 3: Cut Out the Second Card
Just slice out using the top card as a template.
Check the memorystick in each slot to make sure its a snug fit.
Step 4: Cut Out the Notches on Both Face Cards.
Slice out some notches so you can pull out the cards when needed.
I just went for the straight edges for this one but if I make another I would like to have tapered edges.
Again I did this free hand but obviously when measured and cut properly it would be much neater.
Step 5: Glue Those to Your Face Cards.
I forgot to cut the notches before I glued down so I did it after lol.
Pretty much the same as step two.
Thin stripes of glue across the body and down the prongs,line up the cards and line up the cards and press together.
Step 6: All Done.
Put your memorysticks in and stick it in your wallet!
I hope you enjoyed my first instructable!
