Introduction: Mending a Split Bocce Ball
When playing All-Terrain Bocce Ball, once in a rare occasion one of your balls might land directly on a non-forgiving rock. We all know that Bocce Balls can take a beating when playing outdoors, through metal studios, or through the farm, but it's when that darn ball lands smack dab on top of a rock when the fun ends.
Let me show you how all hope is not lost, and neither is the time in between your All-Terrain Bocce Ball matches.
Step 1: It's Broken, Now What?
Simple, start gathering some pertinent items to fix it.
Items you'll need:
- Two 2"x1/4" bolts
- 1/4" coupler
- Small tube of epoxy
Tools you'll need:
- Drill press (1/4" bit, 5/8" bit, and a countersink bit)
- Packing tape
- Screw Driver
- Epoxy applicator
Step 2: Drill One Important Hole, Then Two Other Ones.
First things first, clean off both pieces of the bocce ball and then make sure they marry up tight (assuming you had a clean break). Once snug, tape the ball up in every direction.
Then find the most perpendicular point from the horizontal break to drill through with the 1/4" bit. This will be approximately the furthest area away from the break on either side. Counter punch these spots then drill all the way through. WARNING: A dusk mask may be wanted/needed at this point, resin will go flying during this process.
After your through with the 1/4" bit, do not take the tape off, instead insert your countersink bit and take enough out of each end so the diameter of your bolt is slightly smaller, leaving the bolt a hair below the surface of the ball.
Step 3: Making Space for the Coupler
Now that you have a 1/4" hole all the way through with a countersunk hole on either side for your bolt, go ahead and take the tape off for this next step.
I had the luxury of a lathe, so I turned my own coupler which is always a treat to have something perfectly true. Still, most store bought couplers should work. At this point, match up a drill bit with the diameter of your coupler - The hole should be a hair wider then the coupler.
Go ahead and split the length of the coupler and sink that into either side of the inside of the bocce ball. This will carve out an area for the coupler to receive both bolts entering from either side. The hole on each side should also go a hair deeper then the coupler to allow for a little room for tightening, leaving it tension free.
Step 4: Dry Run
Go ahead and assemble as a dry run. After you hand tighten the two bolts down equally the ball should be pretty snug and fit perfectly back together.
Always good to do a dry run.
Step 5: For Good Measure...
A smart last step before you epoxy is to randomly place some small drill holes on both inside surfaces of the broken bocce ball. This will allow room for the epoxy to spread into and cling onto the outward edges of the ball.
Your 1/4" bit will work for this.
Step 6: Bocce Ball, Meet Epoxy.
Epoxy away. Get enough in there so it squeezes out on all sides equally. Go ahead and crank down on your bolts. You should feel confident in your work to hand crank down on the two bolts for a tight tight bind.
Scrape away any seeping epoxy until it stops.
Step 7: Game On.
Just wait a good 24 hours before you commence playing, and then don't stop playing for a good 24 hours.
Oh, and watch out for those darn rocks.
14 Comments
11 years ago on Introduction
To begin playing you dirty tweets bureau to purchase a exams tweets bocce exhilaration set. A bocce orb draft consists of eight bocce fury and one pallino. a authority notebook and crossing good morning tweets bag are often included as well.crazy tweets bocce orbits sets come in a blend of waistband sizes.
15 years ago on Introduction
Bocce Ball is a game in many countrys where you throw colored balls at a white ball and see which color team is closest overall
whats bocce ball
Reply 15 years ago on Introduction
You can't use Google or Wikipedia?
http://en.wikipedia.org/wiki/Bocce_ball
when i play bocce, i use real bocce balls made of crushed up quarts
you use quarts? I only use gallons unless I'm feeling particularly competitive in which case I use bushels.
sorry i meant quartz
I'm a loser.. I use cups :<
I just skip the bocce and go straight to pints...
The amazing thing is that it's possible to play bocce so hard that you bust the ball. What a remarkably clean break. This is a great fix. I probably would have just epoxied the whole thing together in a sloppy mess. However, I would think a pair of hilti inserts - a quick-bolt in one half and a regular insert in the other - would make a quick and easy fix, rather than having to turn your own coupler?
wtfs a bocce ball?
15 years ago on Step 7
ingenious thinking. great pics too!
that's one ball that has seen a lot of bocce action, nice instructable!
Somehow I think that was overkill, but oh well, good instructable.
