Introduction: Mercedes C E CLK W203 W211 W209 Class Door Lock Actuator Spring Lock Repair Instructions Rear Door
Door lock bouncing up and down? Finding it increasingly difficult to lock your Mercedes?
The Springs within the door lock actuator mechanisms deteriorate over time, the OEM spring is made from cheap metal which wears quickly, this wear leads to the symptoms noted above.
Simply install our improved design replacement springs and restore your locks for good.
Made from high quality Stainless Steel (will not deteriorate over time like springs offered by some others) our improved design thicker wound springs will restore your lock and will not deteriorate over time like the OEM part does, save the cost of a replacement actuator that will just fail again.
Mercedes C Class W203 2000-2007
Mercedes E Class W2112002-2009
Mercedes CLK W209 A209 2002-2009
Step 1: Remove Door Trim
Remove T20 torx and remove lock cover.
Lever off the cover from the door handle.
Remove the two torx bolts under the handle cover (T25, T30)
Step 2: Remove Door Trim
Lever around the edge of the door trim and lift off.
Pull upwards and forwards on the door trim to remove.
Disconnect hook linkage.
Remove insulation to access actuator.
Step 3: Release Actuator
Remove the 3x T30 Torx screws holding the actuator.
If present remove plastic cover.
Step 4: Remove Door Handle
Pry off plastic cover.
Remove blanking plate and unscrew T20 torx holding outer door handle.
Remove handle, firstly remove small part of handle released by removing the previous T20 Torx then slide handle in to recess left from this to release from vehicle.
Remove the two exposed T20 torx screws which will release the bearing clamp.
Step 5: Remove Foam Block
Remove foam block, this sits in front of actuator preventing removal.
This consist of two blocks as shown these slide togther, slide the two blocks apart and remove.
Step 6: Remove Bearing Clamp
Remove bearing clamp.
Step 7: Remove Actuator
Slide actuator out of position and remove.
Step 8: Fit Replacement Spring
Lever off actuator cover.
Replace spring as shown, remove any remains of old spring if in place.
If there are remains of the spring deep in the top white recess it will be hard to remove, you will need to drill this out from directly above using a 1mm drill piece.
Using the pliers insert the top leg of the spring in to the top white recess, if you are unable to do this it is likely that there is still remains of the old spring in place, if so please drill these out as noted above.
Attach pliers firmly to the bottom leg of the spring and force in to bottom recess, some force will be required, do not worry the spring will not snap.
Once in place slide bottom leg of spring in to the smallest part of the recess. Test function to make sure spring is seated correctly; test again when reattaching actuator to vehicle.
Installation is carried out at installers risk, if unsure please contactus or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2013.
