Mercedes M ML Class W163 1997-2005 Door Lock Actuators Spring Springs Repair Part Kit Fix Install Instructions Guide
Intro: Mercedes M ML Class W163 1997-2005 Door Lock Actuators Spring Springs Repair Part Kit Fix Install Instructions Guide
The Problem
A spring within the door lock actuator mechanism snaps causing the locking faults.
It is a common fault on these vehicles for a small spring within the door lock actuator to snap causing the symptoms noted. The original spring within the mechanism is very thinly wound and is constructed from a poor quality steel which will inevitably corrode and the spring will snap. Previously this necessitated the complete replacement of the door lock actuator unit at vast expense, the vehicle manufacture has not altered the spring design / construction over the years so even installing a complete new actuator would only be a temporary solution.
Symptoms of the fault
Door lock jumping up and down quickly, door not locking or only periodically, door lock rattles.
Vehicles affected and compatibility
Mercedes ML Class W163 1997-2005
Some of the models affected:
Mercedes-Benz M-Class W163 ML 230
Mercedes-Benz M-Class W163 ML 270 CDI
Mercedes-Benz M-Class W163 ML 320
Mercedes-Benz M-Class W163 ML 350
Mercedes-Benz M-Class W163 ML 400 CDI
Mercedes-Benz M-Class W163 ML 430
Mercedes-Benz M-Class W163 ML 500
Mercedes-Benz M-Class W163 ML 55 AMG
Some associated part numbers:
A1637302135, A1637302136, A1637201735, A1637301135, A1637302335, A1637301235, A1637201235.
Our solution
Our replacement improved design / material springs allow you to repair the actuator.
Made from high quality Stainless Steel (will not deteriorate over time like springs offered by some others) our improved design thicker wound springs will restore your lock and will not deteriorate over time like the OEM part does, save the cost of a replacement actuator that will just fail again. Produced to the finest tolerances for the perfect fit, thicker wound and reshaped to provide a permanent solution to the locking faults noted above.
From X8R Ltd www.x8r.co.uk
STEP 1: Fitment of New Spring
- Grasp the spring with the forceps as shown in the first image.
- Locate the spring end in to the hole on the underside of the black plastic part as shown in the first image, in the second image you can see where the hole is located on the underside of the black plastic part.
- Once located on the underside, rotate the spring and force in to the channel shown in the fourth image.
- Test the function of the actuator.
If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk.
Please also check out our instruction guide on YouTube.
www.x8r.co.uk
Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2013
