Introduction: Messing With Arduino Simulator
Circuits.io woo!
Step 1: Detecting the Button Presses
Make a circuit to detect when a button is pressed. You can view this in the Serial monitor in the Circuits.io webtool. This is the code:
const int buttonPin = 2;
int buttonState;
void setup() {
pinMode(buttonPin, INPUT);
Serial.begin(9600);
void loop() {
buttonState = digitalRead(buttonPin);
Serial.println(buttonState);
delay(100);
Step 2: Mess Around With the Circuit.
Same code, but change the circuit around to see what happens. Answer: Nothing.
Step 3: Dimming an LED
wire it up to dim the LED using analogue output, PWM, which stands for Pulse Width Modulation.
CODE:
int led = 9; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup() {
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
I could not get anything to happen.
Step 4: Servo Motor!
Getting motion to happen with the arduino.
CODE:
#include
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
void setup() {
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop() {
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180
degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in
variable 'pos'
delay(15); // waits 15ms for the servo to reach
the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0
degrees
variable 'pos'
the position
