Introduction: Metal Coaster
This is a simple metal coaster for the outdoors using recycled parts.
Tig welder
1/16 er70-2 filler rod or other 1-16 mild steel rods
random nuts and washers
Step 1:
Set the welder to a preferred amps or use my settings as a base line.
Step 2: Shape
layout the desired shape for your coaster.
Step 3: The Outside
Weld the outside so that the work piece holds its shape use a small clamp to close the small gap that may occur for the last weld.
Step 4: Fully Weld
Fully weld the inside of the coaster working from the outside in so that there is no missed welds.
Step 5: Cleaning
Clean up the piece so that you can spray it with clear or paint.
