Metal Stamped Believe in Yourself Bracelet
Intro: Metal Stamped Believe in Yourself Bracelet
Make this bracelet in less than an hour!
STEP 1: Tools Needed
- Green Girl Pewter Rectangle Stamping Blank
- 7mm Jump Ring
- Round Nose Pliers
- (2) Chain Nose Pliers
- Flush Cutters
- Script Letter Stamps
- Deco 1.5mm Uppercase Letter Stamps
- Ergo-Angle Hammer
- Steel Block
- Stamp Straight Tape
- Stamp Enamel
- Polishing Cloth
- 6-7" of chain
- Clasp
- (2) Beads
- 6" of 20 gauge wire
- Q-tip
STEP 2: Apply the Stamp Straight Tape
Center Stamp Straight Tape horizontally on the pewter blank.
STEP 3: Begin to Stamp
- Using the Script font, stamp the word of your choice on the blank, aligning the first letter with the left side of the blank.
- Align the bottom of the letter stamp with the top-line of the tape
- Using the Ergo-Angle hammer, strike the stamp with medium force at a 90 degree angle
STEP 4: Move the Stamp Straight Tape
Place Stamp Straight Tape approximately 3mm below the script word.
STEP 5: Use the Deco Letter Stamps
Using the Deco font, stamp the remainder of the phrase on the blank, aligning the last letter with the right side of the blank side of the blank.
STEP 6: Continue to Stamp
Stamp the remainder of the phrase from right to left.
STEP 7: Highlight the Stamped Word With Stamp Enamel
- Use the Q-tip to ensure the enamel completely covers the impression
- Wait 10-20 seconds
- Blot with a soft cloth
- Wipe away the excess stamp enamel with a soft cloth
STEP 8: Make a Loop in the Wire
Using the round nose pliers, make a small loop in one end of the 20 gauge wire
STEP 9: Thread Bead on Wire
Thread the bead onto the wire and cut the wire with the flush cutters, leaving approximately 1” of wire at the end.
STEP 10: Make Another Loop
Make a loop on the other side of the bead and cut the excess wire using the flush cutters.
STEP 11: Attach the Beads to the Stamped Pewter Blank With Jump Rings
- Hold one pair of chain nose pliers on each side of the opening
- Move the ends past each other to open and close the jump ring
STEP 12: Assemble the Bracelet
Attach the chain and the clasp using jump rings.
STEP 13: Check the Jump Rings
- Make sure that the jump rings are closed securely by moving the ends past one another laterally.
- You will hear or feel a “click” when the jump ring is closed properly.
2 Comments
kart15 7 years ago
so nice
impressart 7 years ago
Thank you!
