Introduction: Micro-Fiber IPod/iPhone Case
I needed a case to protect my shiny new iPod Touch, The problem was i didn't want a bulky silicone case and nor did i want a fashionable but unpractical one, this and i didn't want to buy something i can make :P
I brainstormed some ideas and my biggest concern was i didn't want the materials to have sharp edges that could scratch the screen, after searching through my some of my limited resources i found some black foam, i also found a microfiber cloth to line the inside of the case with.
As the case is in your pocket or bag the weight of the iPod/iPhone shifts and it rubs against the microfiber cloth which in turn polishes and cleans your device ! Simple !
Now this is how you make it !
Step 1: Materials/Tools
Materials
- Foam (about 5mm thick)
- Elastic
- Super glue
- Microfiber Cloth
- X-Acto knife
- Ruler
Step 2: Measuring
A big part of this project is getting the sizing right.
You need to measure
Once you have the measurements, mark them out on your foam.
You need to measure
- Thickness of foam
- Width of device
- Height of device
- Thickness of device
Step 3: Cutting
Now you have your foam all marked out use your X-Acto knife to cut the sections out..
That is all...
That is all...
Step 4: Assemble and Check
Now you have all the sections cut out you need to assemble them without glue to make sure they fit !
Step 5: Glue !!
Pretty self explanatory, assemble like in previous step but this time with the sticky stuff...
Step 6: Increacing Efficiency
As a utilitarian kinda guy i decided i wanted to cut a two notches to improve my case, one for headphones and one to make it easier to open the case lid/flap
(refer to pictures)
(refer to pictures)
Step 7: Microfibre Inlay
First you will need a micro-fiber cloth, if your mum is around ask her, she may have one in her cleaning stuff. If she doesn't you can buy one from most shops that sell cleaning stuff.
Chances are the cloth will be rather large so you will need to cut it down to size.
Once you have cut it tho sides will be open and the cords will start to come loose, to stop this get a match or a lighter and singe the sides of the cloth, this melts the fibers back together.
Now you can glue it into your case !
Step 8: Red Strap
My case looked a tad boring all black, and the front flap kept on popping up so i decided to make a little elastic strap to keep it in place, You could just use an elastic band but that would be ~~easy~~ lazy...
To make the band I used two old elastic shoe laces, i cut it down to the right size and then used some super glue to hold the ends in place, i then used some red thread to make it stronger
Step 9: Finished !!
There you have it, a functional, stylish, easy-to-use, cheap iPod/iPhone Case !
Thanks for reading/making !
p.s. if you do make this, post a picture !
As usual it would be great if you could comment and vote !
More projects here !
