Introduction: Micro Golf
You can now take mini golf anywhere you go!
  • Drill
  • Wood
  • Fake grass
  • Staple gun
  • Wood glue
  • Skill saw
  • Paddle Bit
  • Caliper
  • knife
  • Marble
  • Metal rod
Step 1: Cut Base, Add Grass
Cut the "L" shape base out with the skill saw. Then add some wood glue and spread it around for there to be no lumps of glue. After add the fake grass over it by using scissors or a knife, cut the outline of the "L" shape, now let it dry.
Step 2: Sides
Cut the 3 foot long wood into the same length of the sides and hold it there. Then use the staple gun to staple it and aim it near the bottom so that no staples show from the top.
Step 3: Obstacle
The 2 walls are 1 1/2 in, add one to the right side and on the left side. Then add a corner piece that is 2in long as well as a triangle near the end that is 1 1/2in long.
Step 4: Hole
Now make a hole using a drill then add the paddle bit to it, that can make a hole big enough to fit a marble. Then use a caliper to see the size of the hole so you can cut out the grass the same size of the hole and put it in there. When making the hole make sure its behind the triangle.
Step 5: Time to Play!!!
How many hits it take you??
