Micro:Bit Puppet "Text Messaging"!
Intro: Micro:Bit Puppet "Text Messaging"!
Nearly all of our wireless communication is done using radio waves*, including phone calls, text messages, and WiFi. With its built-in radio transmitters and receivers, the Micro:Bit microcontroller makes it super easy to build all sorts of projects with radio communication.
This particular project is a simple & quick way to send text messages between two Micro:Bit** microcontrollers – the sender writes a (short) message that is transmitted via radio to the receiving Micro:Bit, which shakes a lil’ puppet using a servo motor, and then displays the message on the Micro:Bit LED screen. Each Micro:Bit can be both a sender and receiver.
It’s sort of like a two-person Twitter.. if the tweet notified you via dancing cardboard robot puppet!
*Radio waves are long-wavelength light waves. Check out the electromagnetic spectrum here!
**A huge THANK YOU to Adafruit for donating the Micro:Bit microcontrollers used in this project for educational purposes! yayy thank you for supporting this educational endeavor!! :D
STEP 1: Materials & Tools
- Cardboard (approx. 2 ft. x 1 ft.)
- Paper Fasteners (13 or more)
- Skewers (5 or more)
- Hot Glue Gun
- Scissors and/or utility knife (e.g. exacto knife)
- Pencil
- Ruler or other straightedge
STEP 2: Build the Incoming Message Alert Puppet!
Step 1: Build a cardboard puppet like the one shown in the photo or create your own! Use the paper fasteners to make joints.
Step 2: Build a mounting system to attach the puppet to the servo with skewers and cardboard.
I used a magnet to attach the puppet to the servo mounting system because magnets are awesome, but you can also use glue, tape, velcro, or a variety of other adhesives!
Step 3: Build a stand for the puppet.
- On an approx. 6 in. x 12 in. cardboard sheet, measure, mark, and cut a hole for the servo body so that the arms of the servo rest against the front of the cardboard sheet.
- Cut two triangles out of cardboard and glue them on the back of the stand so that the stand, well, stands upright!
- Cut a hole for the Micro:Bit wires to thread through and add two pushpins on the front to hold the Micro:Bit.
STEP 3: Code the Two Micro:Bits!
To start, choose one Micro:Bit to be the sender and the other Micro:Bit to be the receiver. Once both are working as expected, add in the code for both roles.
Use the Make Code Micro:Bit website to program each Micro:Bit. As this is intended as a beginner project, the whole system can be built using the block-based programming language, although adaptations are encouraged and appreciated!
If there is more than one pair of Micro:Bits in the room (i.e. in a classroom setting), remember to set different radio group numbers for each pair.
The sender sends a (short) text based on user inputs over radio, like the example above. Pretty simple!
The receiver moves the servo when an incoming text is received, then scrolls the message text on the LED screen, like in the example below.
Press the reset button to stop sending/receiving the incoming message.
STEP 4: Connect the Servo!
Connect the servo red wire to the Micro:Bit 3V power pin, the servo black wire to Micro:Bit ground pin, and the servo white (or yellow) wire to the Micro:Bit input pin P0.
STEP 5: Send All the Messages!
Program both Micro:Bits to be both a sender and a receiver so you can communicate back and forth. Then switch power from the laptop to the battery pack and test out your wireless communication system! When the sender sends a message, the puppet will notify you to check the LED screen so that you can see the incoming message.
How far of a range can you get? Test it out!
There are tons of other extensions to this introductory project, here are some possibilities:
- Add more message options by adding more inputs or changing how those inputs are read;
- Instead of a table-top alert system, build a wearable alert system;
- Send voice messages and/or other sounds.
Happy building!
5 Comments
tcsarni 7 months ago
roshonaj 5 years ago
Hello thank you for making this neat project. I'm trying to use this in my classroom(3rd-5th). Would it be possible for you to post the hex file for the receiver? I have everything you posted minus the grey "break" block you have above.
Thank you.
jenfoxbot 5 years ago
That's awesome! Stoked to hear that you are incorporating this into the classroom! And yes, I'll post the hex file on my GitHub account tomorrow (https://github.com/jenfoxbot).
Looking at the file quickly, I'm unsure if you need the break, I think I wrote it in Javascript and forgot to delete it. Try testing the code w/out the break to see if it works.
Thank you very much. I tried it without the break and it works great. I'll post pics of my robot puppet. This was a fun project and I know my students will enjoy it.
