Introduction: Microbit - Myoware Muscle Sensor
This is just a quick guide to show how you can connect a Myoware Muscle sensor to a micro:bit. The Myoware sensor can sense the tension of muscles, which is pretty cool, since it allows you to control your projects with your muscles.
1 x Micro:bit
1 x Motor:bit
1 x Myoware Muscle Sensor
1 x 9 volt battery + battery holder
3 x Jumpwires (Male to female)
3 x Jumpwires (Alligator to alligator)
3 x Disposable Surface Electrode
Some wire (I use some in white, black and red)
Tools:
Soldering tools
Wire cutter
Step 1: Soldering Wires to the Myoware Muscle Sensor
So the first thing you want to do is to solder some wire to the myoware muscle sensor. From now on I shall just call it the muscle sensor.
I soldered
red to + (Voltage)
Black to - (Ground)
White to the last hole
Step 2: Put the Electrodes on the Micro:bit
Step 3: Wiring
Use the jumper wires to connect:
+ (Red/Voltage) to 5 volt on the motor:bit
- (Black/ground) to gnd on the motor:bit
Data (White wire) to pin 10 on the motor:bit
In theory the myoware sensor should be able to run directly from the micro:bit, but I find that its performance becomes to bad to really be useable.
Also connect the battery holder and battery to the motor:bit.
Step 4: Programming
The programming is rather easy. Remember I am danish, so the lanuage in the prorammer is sadly in danish.
First we go to the Makecode editor and start a new project.
We use AnalogRead on pin 10 where the myoware sensor is connected. The muscle sensor will give us a number betwen 0 and 1023, so we use the "map" block to get a number bewten 0 and 9 instead. We want the number to be a whole number, so we use the "Round off" block. We then show the number by using a "Show number" block in a "Forever" block.
You can also just find the program here.
Step 5: Now Test It
Put the eletrode pads on a big muscle group and try it out.
The myoware sensor is actuelly really sensitive when you use it with 5 volt and you will get a whole new level of awareness about when you tense or relax your muscles.
