Introduction: Microbit Noise Mod
Ugh. My microbit has no speakers. Why is there noise options when coding then? Well you have came to the right place. I am going to show you a simple headphone noise hack (And now you will finally use that golden strip on the bottom).
What You Need
- Micro Bit
- 2 Alligator Clips
- Headphones or Speaker
- Micro Bit Power Supply
- And a code with noise!
Step 1: Step 1
The first step is the easiest. All you need to do is put a clip on the ground hole and the 0 hole.
Step 2: The Last Step
Wow. Already the last step is here. Well, All you need to do is the ground cable on the bottom part, and the 0 cable on the top part!
Step 3: All Done!
Wow! That was quick! And now you have a speaker for your Microbit! Hope you have fun making music. Thanks for reading! Also, this is an entry for the Modify Challenge. Please vote me! It helps!
