Introduction: Microphone Lights LED
Step 1: Parts
1. Arduino
2. Wires
3. Microphone
4. 7 LEDs
5. Breadboard
6. Resistor
*pictures are in order of parts
Step 2: Coding
After the idea of lighting LEDs based on sound was agreed on, a code was needed. In order to make sure each light was independently accounted for a code, we needed to give each light a code as to when they should light up.
Based on the sound the microphone measures the lights would respond accordingly. The sound range of our lights varies from 5-1000. This means that every light would light at a certain point between 5-1000. Each light was programmed to their own 'off and on' code.
The code goes as such:
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
pinMode(A0, INPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(7, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
void loop() {
// put your main code here, to run repeatedly:
int val = analogRead(A0);
Serial.println(val);
if (val > 750) {
digitalWrite(6, HIGH);
if (val < 750) {
digitalWrite(6, LOW);
if (val > 850){
digitalWrite(5, HIGH);
if (val < 850) {
digitalWrite(5, LOW);
if (val > 900) {
digitalWrite(7, HIGH);
if (val < 900) {
digitalWrite(7, LOW);
if (val > 1000) {
digitalWrite(3, HIGH);
if (val < 1000) {
digitalWrite(3, LOW);
if (val > 5) {
digitalWrite(2, HIGH);
if (val < 5) {
digitalWrite(2, LOW);
if (val > 100) {
digitalWrite(1, HIGH);
if (val < 100) {
digitalWrite(1, LOW);
if (val > 200) {
if (val < 200) {
if (val > 600) {
digitalWrite(4, HIGH);
if (val < 600) {
digitalWrite(4, LOW);
Step 3: Building
In order to make sure the code and board function perfectly together, it must be built accordingly.
*referring to picture 1
Explanation: Each wire must correspond one LED and the Arduino.
*referring to picture 2
Explanation: Be sure to include a resistor
*referring to pictures 3 and 4
Each wire goes to a specific place on the Arduino so make sure it is followed exactly as the picture shows
