Microwavable (Rice-Filled) Heating Scarf
Intro: Microwavable (Rice-Filled) Heating Scarf
I am always cold. While the rest of my family sits comfortably in our home, I require comfort from heated rice bags, a flannel shirt, and slippers to be comfortable. As you can imagine, I'm also generally colder than my family when we are outside, which is probably why my kids suggested that I make myself a microwavable, rice-filled scarf as well.
If you happen to be cold like me, this Instructable is for you and will show you how to make a functional and fashionable, rice-filled scarf that you can whip up in less than an hour.
STEP 1: Cutting the Pieces
Lay your fabric out flat and doubled so that you will cut two pieces at one time. Cut the fabric into an 18" wide strip that is at least 42" long. (The scarf created in this instructable is 42" long, but feel free to use this cutting strategy with a shorter or longer length if that is your preference.) At one end, put a pin halfway across the fabric (9" from the edge). Then, from the other end, cut from one corner of the bottom edge toward the pin in a straight line (as shown). Repeat on the other side until you have two triangular pieces of fabric.
STEP 2: Sewing
First, pin the "right sides" together along the bases of the triangular pieces and stitch along the edge to create one long (~83") scarf.
Then, stitch along the complete perimeter of the scarf (about 1/4 - 1/2" from the edge). This stitch is there primarily to make sure the fabric won't be able to fray too far. (I prefer a little fraying and distressing along the edges of a scarf - see Step 4 - but not too much. I like to add this stitch to control that fraying.)
Once you have sewn the perimeter, fold the scarf in half (longways, as shown in the picture) and pin an inner triangle that will become a pocket for rice later. To pin off this inner triangle, start by placing a pin approximately 3 inches from the fold (at the largest part of the triangle, the middle of the scarf) and then taper back toward the fold parallel to the edge of the scarf (as shown). Once you have pinned off the pocket, sew along these lines almost all the way,* but make sure to leave at least 2 inches unsewn at the end to allow space to fill the pocket with rice.
*Note: Make sure your stitch length is small enough so that rice won't be able to sneak through your sewn edges. Having a big, open stitch would likely result in you leaving a trail of rice the first time you wear your scarf. :)
STEP 3: Filling With Rice
If you have a funnel, this is a good time to break it out. If you don't, simply roll up a piece of paper into a cone shape and that should do the trick as well. Make sure the end of your funnel is inserted fully into the end of the pocket that was left open and begin pouring in the rice. This scarf holds approximately two cups of rice in the pocket, but keep filling until the pocket at least 3/4 full. (If you fill it too full, it will be very challenging to stitch closed with a sewing machine.) When you are finished adding rice, stitch the last few inches of the rice pocket closed.
STEP 4: Distressing
I wanted my scarf to look a little less "perfect", so I took my seam ripper and roughed up the edges of my fabric a bit. You can also simply pull on the fabric with your hands along the edges to make it appear slightly worn. This step is purely a personal preference for how you want it to look, so feel free to skip this if you are happy with the way it looks without distressing it.
STEP 5: Microwaving
And that's it! You're done!
Depending on how much rice you end up filling your scarf with and what sort of microwave you have, you may need to test different amounts of time in the microwave, but for my design one minute was just the right amount of time to make it super cozy and warm to wear.
Now all that's left to do is to think of all the ways you'll want to enjoy your new, functional accessory. If you are like me, that might mean you get to enjoy sitting through a meeting in a cold space with a secret neck heater that makes you so, so happy...or that you don't dread the wait for the bus to come for your kids on a cold day...or that you just can't stop wearing it because you had forgotten what it feels like to be warm in the winter and you have become obsessed...
However you choose to use it, I hope you stay warm :)
17 Comments
snowf7 2 months ago
Polymer crystals (gel beads) can be used in place of the rice to stay cool during a heatwave.
lainealison 2 months ago
Interesting! Thanks for the idea!
1alembic 2 months ago
Excellent idea and post. Thank you.
StringGoddess 2 months ago
I've sometimes wished there was an easy way to tie one of my rice bags around my knee, and here it is! Thanks.
j1shalack 2 months ago
Great tutorial.
I made one some time back and used dried beans as the fill...
Many times...
calichigal 2 months ago
And you heated it up in a microwave oven?
I've never tried working with beans. Which holds heat longer?
I really like this idea of making a scarf to warm up oneself when cold. It could be wrapped around feet, too, I would think. I have rice-filled tube socks, that get used fairly regularly for sore muscles. Most are just tied closed, making it easy to empty and wash the sock, then refill.
Having a way to wash it like that is a great idea!
slim49n 2 months ago
I made. A cruder Version many years ago. Using a tube sock. Lasted for years
I still have LOTS of rice-filled tube socks, that get used fairly regularly for sore muscles.
I think beans may...
jeanniel1 2 months ago
Very clever and easy to make - yes, I love that it's also quick to warm up for use! The artfulness of your design makes it unique. Great job!
Thanks so much 🙂
AjarDesign 2 months ago
That’s really cool! I’ve never seen something like it before
Thanks so much! After we thought of it, I couldn't believe it wasn't already out there!
