Introduction: Midi Monitor V1.0
parts, pcb gerber files and drawings need updating. this is just a rough layout, will be complete soon.
ATmega 256 cpu reading midi data and driving 3 Phillips SAA1099, 8
bit, 6 channel sound chips for 16 polyphonic square wave channels and 2 polyphonic white noise generator's for precussion.
Midi data is sent from the sound cpu to another ATmega 256 cpu driving four rows of 12 SN74HC595 8 bit shift registors driving a 90x4 led array. Each led is addressed using midi note on/off numbers for X and channel numbers
for Y. channels 4 - 16 are mixed in the lower row
Example 1 Bach - Goldberg Variations
Example 2 Bach - Little fugue in g minor
Step 1: Assemble LED Boards
PARTS//
5mm LED's x 360
40x2.54 female header x 8
6x2.54 female header x 8
LH led board PCB x 2
RH led board PCB x 2
Step 2: Assemble Row Drivers
PARTS//
LH BOARD//
SN74HC595 8 bit shift register x 6
Right angle 40x2.54mm male header x 1
Right angle 6.2.54mm male header x 1
16pin IDC female right angle header x 2
Capacitor 1206 SMD 0.1uf x 6
LH LED driver slave V5.0 PCB x 1
RH BOARD//
Right angle 40x1 2.54mm male header x 1
Right angle 6x1 2.54mm male header x 1
16pin IDC female right angle header x 1
RH LED driver slave V5.0 PCB x 1
Step 3: Assemble Led Driver Assembly's
Step 4: Assemble LED Row Driver Card's
PARTS//
LED DRIVER BOARD//
ATMEGA 256 Microcontoller x 1
FTDI FT232R usb to serial converter x 1
PC18 Sharp optical isolator x 1
USB type A female socket x 1
16mhz crystal x 1
40x2 pin IDC right angle header x 1
3x2 male header 2.54 pitch x 1
small diode x 1
LED 1206 SMD x 4
resistor 1206 SMD 1k x 4
resistor 1206 SMD 10k x 1
resistor 1206 SMD 220 ohm x 1
resistor 1206 SMD 270 ohm x 1
capacitor 1206 SMD 0.1uf x 6
capacitor 1206 SMD 22pf x 3
capacitor SMD 100uf x 1
8 x 5.08 pitch plug x 1
Led master driver card V1.0 PCB x 1
4 ROW ADDAPTOR BOARD//
16x2 pin IDC female header x 4
40x2 pin IDC female header x 1
LED 1206 SMD red x 1
resistor 1206 SMD 150ohm x 1
100uf SMD capacitor x 1
4 row driver PCB x 1
Step 5: Assemble Sound Card
PARTS//
ATMEGA256 cpu x 1
Pillips SAA1099 sound IC's x3
PC18 sharp optical isolator x 1
5v buzzer x 1
8mhz Oscilator x 1
OELED LCD screen x 1
4 bit dip switch x1
pcb push buttons x 6
8 pin x 5.08 header plug x 1
USB type a socket x1
