Introduction: Milk Carton Bike Fender
This is a quick project to make an awesome waterproof bike fender using a half-gallon milk carton and four plastic zip ties.
Required items:
an empty half-gallon (2 liter) milk carton (either with or without the capped spout)
a good pair of scissors
a permanent marker
hot glue gun or comparable adhesive
4 zip ties (available at your local hardware or electronics store)
When finished, the fender attaches only to the seat post stays of the bike's frame
Step 1: Open the Top
Rinse the carton really well.
Open the entire top along the seam so that the top is completely open.
Step 2: Cut It Up!
Cut with scissors into two parts as shown.
The half with the spout (at right) will become the front half of the fender. This is the part that will wrap around and attach to your bike frame.
The other half will become the back of the fender.
Step 3: Back Half of the Fender
This is the back half of the fender.
Cut a notch out of the bottom of the carton to allow clearance for the tire. This might not be necessary for all bikes but it doesn't hurt.
Step 4: Front Half of the Fender
Cut both corners so that the bottom is free from the sides.
Step 5: Attach the Two Halves
Withe two pieces laying top down, set the back half on top of the front half so they overlap by about 4 inches (100mm).
Mark the location and heat up the glue gun.
Apply glue to one mating surface of the carton and press the other half on top.
Repeat for each of the sides.
Step 6: Cut Notches to Fit Frame
Notch the top of the spout as shown.
These should be about 1/2 inch (12mm) wide and 3/4" (18mm) long.
Step 7: Pre-roll the Side Flaps
It helps make installation easier to pre roll the flaps that wrap around the frame.
I used a sharpie to help shape the flaps.
Step 8: Put It on Your Bike
Wrap the pre-rolled sides of the fender tightly around the frame so that it wraps all the way around.
Holding the fender with one hand, make slits 1 inch (25mm) below the top and 1 inch (25mm) above the bottom for the zip ties.
4 Comments
10 years ago on Introduction
awesome indeed! i just installed this on my zerobucks-bike. it's much more durable than i thought it would be. and my friends are all over this fender!
even though i ride really fat mtb-tires, i used only a 1 liter milk carton and i think it fits really nice and tight
i believe you could use milk cartons as a front fender as well. i haven't figured yet how, though.
anyway, thank you for your great instructable!
Thanks for the comment ganjamanja!
I'd love to see a picture if you take one.
I would probably use more durable material so my work produces a longer lasting benefit. I made a similar fender by slicing PVC lengthwise and attaching it with metal fittings. It has lasted more than a couple of years and will last a long time.
The first one I made for last winter made it though to spring. It got me through the rain and sludge of Seattle riding every single day. I don't like using fenders when the weather is nice so I take it off when the sun shines. At that time I can put it back in the recycling bin where it came from. That, and all the folks who take interest in it, keeps me smiling through the muck.
Thanks for looking.
