Introduction: Milk Carton Opener
This is a 3D printed milk carton opener. It is intended to stabilize the milk carton so that you can open the milk only using one hand. This works best if a piece of dycem mat is placed underneath so that it does not slide all over the table.
**This idea was originally created by Nuege Xiong from Harding High School** All credit goes to him
  • 3-D printer
  • Tinkercad account
  • Glue gun
  • Measuring tape
  • Milk carton
Step 1: Measure the Desired Container
For this step, you will want to measure the carton you want to be able to place in the container, and convert it into millimeters.
Step 2: Create the Design in Tinkercad
After the measurements are converted, create the design in tinker-cad using a box with a hole in it, and then add supports to the side using another box with a hole in it. An example templet is provided below.
Step 3: Create the Side Supports
Create the side supports so that it does not tip over. An example file is provided below.
Step 4: Assemble
Hot glue the supports to the side, and attach a piece of dycem to the bottom. Place the milk carton in the main compartment and enjoy!
