Milk Jug Skulls
Intro: Milk Jug Skulls
These skulls are made with the gallon size milk, water or ice tea jugs! The plastic jug is melted and shaped over a master skull.
STEP 1: Tools Needed
To get started on this fun project there are some things needed.
A RESIN master skull...found on Ebay.
Good heavy gloves
Heat gun
masking tape
hot glue gun with glue sticks
sponge
scissors, razor knife
regular screw driver
bowl of ice water with a towel
plastic gallon size milk jugs!!
STEP 2: Master Skull & Stand
1. I use a resin skull, this one has the removable jaw. I made the stand with some scrap wood and a section of PVC...I drilled a hole through the bottom of the skull but it can just be glued onto the pvc. This stand makes all of the difference!
2. I added some fiberglass matting to the back and top of the master skull to help "beef up" the rear of the skull as we will be cutting off the plastic when it's done.
STEP 3: Prep the Jug
Cut the handle off of the jug.
Place the jug over the skull with the long part covering the face as shown.
STEP 4: Start Making the Skull
Using the heat gun on HIGH, 1st heat up the decals and peel off. This should only take a few seconds
In a circular motion hold the heat gun about 3 inches above the top and keep moving the gun until the jug starts to turn clear.
With your gloves on, pull the soft jug down to take the shape of the skull.
Then heat up the plastic just under the cheek bone until clear and "tuck" in with your gloved hand...repeat on the other side...the jug is now "locked-in"
STEP 5: Detail Work
Now we go back to the top...heat again until clear and now use a sponge dipped in ice water to push the plastic into place...do small sections.
Work your way to the forehead, then each side.
Heat up the area above the cheek bone until clear and push the sponge in, repeat on the other side.
Now do the same under the cheek bone on each side.
heat the mouth area over the teeth and press the cold sponge over the teeth to get the basic shape of the mouth.
Cut off the extra plastic under the mouth, be sure to leave about 1/2 inch extra to fold under the teeth and base.
heat the nose area, when clear push the sponge into it.
Heat the eye socket and push the cold sponge into the socket...don't push in to far or the plastic will tear. Repeat on the other eye.
heat the teeth section and using the cold sponge, fold extra plastic under teeth.
Now heat the teeth again but use a small screw driver to push in between the teeth and get some detail!
STEP 6: Getting the Skull Off the Master
I use some heavy duty scissors and cut up the back of the skull, once at the top I cut a small V shape. Now the back of the skull will open....facing the skull pull the open back towards you...the skull should "pop" off.
Now use some tape and get the seams as close together as possible. Using the hot glue, glue from the inside. Cover the whole seam with a good bead of hot glue. Now peel off the tape once the glue has cooled.
STEP 7: Time to Paint
First I use an ivory flat spray paint and spray a good coat inside the skull.
I use some flat black spray paint on all of the lower sections...eyes, nose, mouth and around cheek bone.
Using some paint thinner I soak a sponge and wipe off the excess paint...I use the sponge with a scrub side...be careful not to take to much off.
Last is a coat of flat interior latex paint...brown..I brush it on and using a water soaked rag I "blot" off the paint....once almost dry I take the sponge and clean off the teeth a bit!
STEP 8: Finish
The skulls are super light...IF using them outside I suggest spraying a bit of expanding foam in them and toss in a handful of stones.
I like to attach the skulls in clusters...you can use the hot glue but I use zip ties and screws so they won't come apart! HAVE FUN!!
STEP 9: BONUS!!
So I have also started to make femur bone ends for a catacomb type display. Using a Bucky femur bone as the master, mounted to another stand. One plastic gallon jug will make two bone ends
143 Comments
LeslieGeee 1 year ago
JasonF205 8 months ago
dannilightfoot 1 year ago
doo da do 2 years ago
dgeer809 2 years ago
OREON_1 2 years ago
Jackn7 2 years ago
Arrrrh!
Barry6470 2 years ago
Well Done, absolutely Fantastic.
MichaelL628 2 years ago
chefspenser 2 years ago
terrefirmax2 2 years ago
sallymcclure 3 years ago
1. What is the fiberglass matting?
2. Where did you add it? Outside?
3. How did you attach it so the heat didn't interfere?
Thanks so much!
Sally
AaronN2 3 years ago
BrianL204 3 years ago
Rocc01 3 years ago
pharojim 4 years ago
JasonF205 4 years ago
tr0lldr0id 4 years ago
