Introduction: Milling Concepts
CONVENTIONAL CUTTING VS. CLIMB CUTTING
Conventional cutting is when the workpiece moves against the direction of the cutting bit.
- All manual mill work should be done with conventional cuts.
Climb cutting is when the workpiece moves in the same direction as the bit.
- This is not advised on the manual mill.
- Climb cutting should be reserved for CNC milling.
CUTTING WIDTH AND DEPTH
An end mill can only remove a certain amount of material at once.
The maximum depth and width of cut is 1/2 of the end mill diameter.
- For example, a 1/2" end mill can cut no more than 1/4" deep and 1/4" wide in a single pass.
- A slotting cut is an exception to the width of cut rule.
USING THE POWER FEED
The power feed moves the table at a constant rate, which can help improve finish quality.
- Turn the speed dial to 0.
- Move the lever in the direction you want the table to move.
- In the illustration, the table will be moving to the right.
- Adjust the feed rate by turning the speed dial.
Step 1: Edge Finding
For accurate work, each axis needs to have a known zero point (origin). There are two ways to determine zero; create it or find it.
CREATING A ZERO
X or Y axis
- Take a light cutting pass to make the edge flat and square.
- Turn off the mill.
- On the DRO (see next lesson) zero the axis.
- In this example, zero the X axis.
- Move the end mill 1/2 its diameter towards the center of the workpiece.
- This will center the spindle over the edge of the material.
- Zero the axis on the DRO again.
Z axis
- Take a light cutting pass across the top of the part.
- Set the Z axis to zero.
- The zero will need to be reset if the quill moves, or you change the end mill.
FINDING A ZERO
X or Y axis
- Install an edge finder.
- Push the bottom of the edge finder over 1/8".
- Start the mill and adjust to 800 RPM.
- Very slowly move the edge finder into the edge of the material until the bottom pops over to one side.
- Zero the axis on the DRO.
- Repeat step 4 to double check.
- Move the edge finder 1/2 its diameter towards the center of the workpiece
Z axis
- Install the end mill.
- Lower the quill (or raise the table with the quill locked) until the end mill gently touches the table.
- Lock the quill.
