Introduction: Mimikyu by Esmeralda
This is Mimikyu from pokemon :3. It one of my favorite pokemon and i try to build it and I wanted to teach you guys how I built it.
The supplies that you're going to need when making Mimikyu out of cardboard are
- Ruler
- Cardboard
- An eraser
- Pencil
- Tape
- Scissor
Step 1: Cutting the Cardboard
So the first thing that you're going to need is a box like in the first picture, and then after you will need to cut the side of the box so that it can open wide like in the second picture, and you can get more space after you're done. You should cut it in half vertically, like in the third one. So that you don't have a difficult time with it.
Step 2: Making the Body
Use the cardboard and draw the body like a it might be like big oval on top, but sides are just straight lines that go straight down, but when getting to the end, it will be like sharp. But they are going to be on different sides because of where they are going to be placed. So the ones in the front and back are going to be 22 cm in height and 16cm in width. While ones that are going to be placed at the side it going to be the height 20 cm in height and the width of 18 cm. For both of them, make two for the sides and front, and back.
Step 3: Putting the Body Together
Once you've got it, you're going to tape it together so that it is 22cm and 16cm, going to be the front side and back is the first one and then the second one is the sides ( 20cm and 18cm) would be tape up front side and then it going to repeat. Then you are going to get another piece of cardboard and draw a square that is about 17cm in height and 16.5 cm in width. Once you cut it, cut a bit of the edges and then put on top of the body, tape it together
Step 4: The Head
To make the head, your going to need a new box, then your open the side of the box so that is wide and cut the middles then, your going to fold it so that it makes like a little box on top on the body but there still going to be a open spot in the head so your going to get another cardboard and cut in the middle and fold it and put it on top and tape it together and put the tape the head to the body
Step 5: Making the Face
So your going to grab another cardboard and make a square but the sides is 14 cm and the width is 17cm (make two for front and back) and then your going to tape in front and back
Step 6: Make the Ears and Tail
So your going to grab a half of a cardboard and you draw the ears and the tails but you can personalize however you want but try to do it like mimikyu ears and tails and draw it far apart so you can cut with calm and once your done tape the tails on the back side and the ears you tape on top and put the tape under the ears so that and after that your done. You can personalize however you like.
