Introduction: MineCraft Cake
I made this cake for my son's 7th birthday..very very easy to make.
2 boxes of chocolate cake mix-or make your own
1 batch of rice Krispy treat
Butter cream icing tinted green
Icing bag
Grass tip
Blue jello
Large base to sit cake on. I use the board used for craft projects found by the poster board these are cheap and can be found at Walmart.
Step 1: MineCraft Characters
The 1st part is to make your figures. I am a self taught decorator only started decorating this year and these little guys were easy..they are just blocks of colored fondant glued together with a little water. Use a small paint brush that you only use for food to ad the water with. Set out to dry.
Step 2: Basic Shape of Design
Sorry don't have a picture of before the decorations were applied but you can see that the cake is just blocks stacked.
I say down and drew out my design on paper first the once I was satisfied I began cutting out blocks in my cake.
The bottom layer is one whole piece of cake with the top layers being the cut out portions positioned to look like a pyramid.
Add buttercream icing between each layer of cake.
Next do the same with your rice Krispy treat. These are the sand.
Remember to leave a cut out open space for the water. This is done by making blue jello.
Step 3: Adding Water and Grass
Once your cake shape is put together you need to add your water.
I put down a piece of wax paper covered in white buttercream in the space the jello was to sit. This gave a really cool look to the water effect I was going for.
Next take the tinted green frosting put into a pastry bad fitted with the grass tip and begin to add grass to top and around the border of your cake.
Step 4: Final Step Add Your Figures
Easiest step of all, add your figures. I only chose to make a few due to having three birthday cake in a three day period, you can make as many as you want.
Place around your cake..I inserted a small Popsicle stick into the bottom of each if my figured so that they did not sink down into my cake. Toothpicks would work as well.
My son loved it.
I want to give credit to every person who put tutorials up in YouTube and Internet. Without them I would never have learn the joy of cake decorating.
