Introduction: MineCraft Creeper Alarm Clock
This is a mine craft alarm clock modeled after a creeper.
it took about 5 hours to create and is fully functional.
and i hope that you will like it.
Things you will need:
*Cheap alarm clock
*Tape measurer
*Hole puncher/circle stamp
*Small speaker
*Cardboard
*Tape
*Paper cutter
*Hot glue and glue gun
*Printer
Please rate if you like it. thnx
*Cheap alarm clock
*Tape measurer
*Small speaker
*Cardboard
*Tape
*Paper cutter
*Printer
Step 1: The Head.
First you need to cut out (6) 4"x4" squares of cardboard
make sure to get them all even so the head is perfectly square.
Step 2: The Body
Now you need to cut out (2) 2"x6" Rectangles
Next you need to cut out (2) 4"x6" Rectangles
They should look like the ones in the photo below.
Now in one of the 4"x6" Rectangles hole punch a
hole big eough for your speaker.
Step 3: The Feet.
Lastly you need to cut out (4) 2"x2" cardboard squares
And cut out (8) 4"x2" cardboard rectangles.
again make sure they match up. you do not want him to be oddly shaped .
Step 4: Creeper Skin.
Now you need to print out 5 of the creeper textures
and one of the creeper heads.
the files are attached below.
Step 5: Apply Creeper Skin
Cut out pieces of the creeper skin And either tape or glue
them to the cardboard cutouts
then cutout the face and attach it to one of the face pieces
Step 6: Put the Head Together
Now align the head like in the picture below and apply tape connecting them all together.
And then tape the head all together.
P.S. if you want to fill it for extra strength
Step 7: Putting the Body Together
First take your speaker and glue t to the back of the chest cutout
then take apart your alarm clock
Cut the wires of the speaker and cut the ends so the wires are showing
Next cut out the rectangle for the display screen
you can put a frame around it like i did to make it look cleaner
then attach the wire to your speaker you glued on (red to red white to white)
now cutout the area for the buttons
and place a cardboard strip behind the circuit board to hold it in place
now attach the buttons
then tape on the other sides of the body and glue them into place
Then glue on the head
Step 8: Feet Assembly
Now put he feet together in rectangles
Then glue them on as in the picture
Now you have your very own creeper alarm clock
