Introduction: Minecraft Castle 2.0
This is going to be a longer instructable because it is so big. But it's worth it. Also thank you everyone i currently have 30 subscribers!!! Can we push for 40 or 50?
Step 1: Finding a Big Place
First you need to find a big place to build. I had no big spaces left so i basically destroyed a mountain for you guys because you rock!
Step 2: The Base
The perimeter needs to be 30 blocks long for front and back and it needs to be 25 blocks wide (the right and left side). Then just fill it in with the type of block you are using.
Step 3: Building the Towers
Now we need to build the four towers. The base needs to be 7 blocks by 7 blocks. And they need to be 18 blocks tall. Repeat this step to get all four towers. And at the top make it go out one block and then place a block every other block like shown.
Step 4: The Walls and Roof
So first you need to build the walls. I built mine five high but it's up to you on what you want to do. Next make the roof. You can make cool designs or make it a plain roof, it doesn't matter as long as you have a roof.
Step 5: Time to Start Decorating
Many of you asked me how to build the throne. So now I am going to show you. You build the base 5 long and 4 wide then fill in the missing blocks.
Step 6: The Seat
Now make the seat 3 blocks long and 2 blocks wide.
Step 7: The Back
Now you make the back of the chair to blocks high and put the fences on for arm rests.
Step 8: Inside Is Done
Now that the inside is done you have to make a second floor.
Step 9: Making the Second Floor
The second floor is 18 blocks long and 17 blocks wide. The walls are also 5 blocks high.
Step 10: Make the Sleeping Area
Step 11: Finally Make the Toliets
Step 12: You Can Make a Third Level
If you want to make a third floor you can because it looks better but it's not really needed. But if you want to build it, the dimensions are 14 blocks long and 13 blocks wide and 5 blocks high.
Step 13: FINISHED
This is the end of this instructable. Remember I am making an instructable on the xbox this week! But until then build on!!!!
