Minecraft House
Intro: Minecraft House
This is my first instructables. Hope you enjoy any questions just ask.
STEP 1: Step1
Build a 13x13 bottom you can use any stone for this part you want.
STEP 2: Step 2
Build the walls up by 6 you can continue to use stone or you can use wood of your choose. I choose to use wood. Place a block then add wool any color you choose. Then continue to do that till you have 6 walls. Leave room for the door. Also leave room for the windows.
STEP 3: Step 3
Add windows and doors. Add a stair case where you put the door.
STEP 4: Step 4
Add the ceiling you can use anything for the ceiling but they have to be slabs.
STEP 5: Step 5
create the roof you can use any stairs you want but make sure the roof is pointed.
STEP 6: Step 6
dig out the grass on the inside of the house and put flooring down you have to use blocks but any blocks it doesn't matter.
STEP 7: Step 7
add flowers or bushes on the outside of your house if you do bushes dig out the grass once and add glowstone for subtle lighting
STEP 8: Step 8
decorate the inside how you want. This is how I decorated mine
STEP 9: Step 9
next to the house create a fenced area attached to the house for crops. Dig out a small square and put water there. Plow the land and plant seeds. This is optional.
STEP 10: Step 10
make a well dig out the ground 7 add stone blocks in front of the stairs on the end of the house to the right do the same thing then add two on both sides diagonal than make a well based on the bath 2 walls high you then add three blocks in the middle of the well and add lava or water than break the blocks holding the lava or water also optinal.
STEP 11: Step 11
you are now finished any questions just ask. Thanks for reading hope you enjoy.
2 Comments
wold630 8 years ago
I like the bookshelf inside the house!
Elizabethb105 8 years ago
