Introduction: Minecraft Mideival House
Hello! If you are reading this, you must be wanting to build a nice medieval house. I will show you a step by step process of making a house. If you see changing things, I made a few tweaks in-between.
Step 1: IItems
The first thing you always do when you want to build is select your inventory. for this build, I chose cobble, spruce and birch. you can use stairs and slabs as long as you use a good color pallet
Step 2: Base
First step for BUILDING is to make the base. I used 2 layers of cobble and 1 layer of oak.
Step 3: Walls (First Floor)
Next up, add the floor to the house and then add walls. Try to Evenly space out the windows and add pillars on the border of each window.
Step 4: 2nd Floor
For the 2nd floor, do the exact same as the 1st thing only go out 1 block. If the windows get uneven, just align them in a nice order
Step 5: Roof/Finnishing Up
Now build a border from the 2nd floor to the roof and add pillars that are, once again, spaced evenly. After that, grab some stairs that match your pallet, then build the roof with the cobble on the edge with the spruce going 1 block out. And PRESTO!!!! You are done! just add a few touchups and even add another floor if you want. I hoped you guys enjoyed this as much as I had building it. See ya!wswwss
