Introduction: Minecraft Obsidian Generator
This is a Minecraft obsidian generator that works in all versions of Minecraft.
It's also reusable!
The pictures and instruction are for a Generator that makes six obsidian
Step 1: Materials
You need:
1 bucket of water for each obsidian block you intend to make,
At least 1 bucket of water, and
Approximately 50 fireproof blocks of your choice
A lot of flat land
( IMPORTANT the water holder only needs to be one block deep, but the lava one needs to be two )
Step 2: Water Holder
This will work in almost any size, as long as it contains water. One block high will do. ( I made mine two high so i could put a cobblestone floor in it.
Step 3: Lava Holder
It needs to be right next to the water holder, with only one row of blocks separating the two.
It also needs to be a block lower than the water holder, so the water gets to the lava first.
I made a step between the lava and water holders on the lava side so the water has a place to run
The lava holder needs to be two blocks deep so the lava has a higher wall around it.
( IMPORTANT- You need to place the lava one a square- for example, if I wanted to make 6 obsidian, I would make the lava holder two blocks wide and three blocks long - six blocks space, and I would put one bucket of lava in each block space, to make six blocks. )
Step 4: Usage
To use, destroy one of the blocks separating the water from the step. If done correctly, the water will flow over the lava, turning it into obsidian. I hope this works for you.
Step 5: Thanks!
The pics aren't perfect but thanks for viewing!
THE CAKE IS A LIE!!!
