Introduction: Minecraft Penguin House
About: "I am a crafty girl. I make things. Lots of things. I'll keep making things until my fingers fall off. Then I will grab my hot glue gun reattach those suckers & Make More Things." Kathy R. Jeffor…
This a adorable house. I made it the first time in survival and I still love it. You can make it as a house or just a big statue. Hope you enjoy.
Step 1: What You Need
For a penguin what you need is
16 orange wool
18 white wool
351 black wool.
If you want to make it a house you also need.
1 iron or wooden door
2 wooden doors
8 ladders
2 stone of wood pressure plates
87 white wool
1 trapdoor
(Optional) 258 white wool (for white walls because I don't like black)
Step 2: The Base
For the base make a oval like you see in the picture with two 2X2 orange wool platforms for the feet.
Step 3: Walls
Now follow the picture and bring up white wool blocks 5 high 3 wide and 6 high in the middle. Then bring up the black walls 11 higher.
Step 4: More Walls
Now level off the whole thing by putting black wool on top of the white wool to level the whole thing off.
Step 5: Beak & Eyes
For the Beak go 1 block above the white and place orange wool 3 blocks and sticking out 2. Then put 2 more blocks on the middle of the flat part of the beak. Then go a block above the beak and place 2 white wool blocks 1 block apart for eyes.
Step 6: Roof
Now put a roof on it on block smaller & higher then the last row of blocks.
Step 7: Inside Walls (Optional)
If you decided to make it a house then go on the inside and (this step is optional) you can cover the walls in white wool. As I did because I don't like how black looks in minecraft.
Step 8: Arms
Now go up 8 blocks on the side and make arms that are 7 blocks long and 1 block wide. While standing on the arm break into the body & repeat this for the other arm. and put one of you wooden doors on each arm.
Step 9: The Inside
For the floor replace the grass blocks with white wool then make different floors. Mine had 3 floors yours can have more if you want. And place ladders on the wall you chose and break through the floors. till you get to the top floor. and place a trapdoor at the top.
Step 10: Decorating
Now you can decorate however you want. I even got a golem friend to come live with me.
Step 11: Door
Now add the iron door and pressure plates. And you are done. I hope you enjoyed this instructable if you did check out some off my others. Don't forget to vote.
