Introduction: Minecraft Plane
Im going to show you how to build a plane in minecraft.
For this build you need:
- quartz slab
- quartz stairs
- quartz block
- light grey stained glass
Step 1: The Front: Window
You need 12 light grey stained glass.
Step 2: The Front: Layer 1 Outside the Window
You need 13 quartz slab. Place them around the glass.
Step 3: The Front: Under the Window
Make a layer under the slabs with quartz blocks. Under the one block in the front it is going to be a slab
Step 4: The Front: 2 Layer Under the Window
Make the layer under with slabs.
Step 5: The Front: 3 Layer Under the Window
Build two slabs.
Step 6: The Front: Walls
build a wall on each sides.
Step 7: The Front: Roof
build the roof on the cockpit.
Step 8: The Body: Walls
Build a 27 block long wall. It is a door at the slab at the start of the wall (If you want to add it).
Build the walls on both sides!
Step 9: The Body: Roof
Build the roof showed on the picture.
Step 10: The Floor
Fill the floor like showed on the pictures.
Step 11: The Tail: Vertical Stabilizer
Build like like in the picture.
Step 12: The Tail: Fill in the Back
Fill in the back.
Step 13: The Wings
Build the wings by looking at the picture and build the wings out of quartz. Build both wings and fill it in with quartz.
