Introduction: Minecraft: Slime Block Shotgun
Hello again and welcome back to another Minecraft instructables by COOLCREEPER69! I will be showing you how to make a Slime Block Shotgun that fires 11 TNTs to about 32 blocks far! This is a quite simple and efficient shotgun that all 11 TNTs will fire together at the same time. Let's begin!
☆You will need:
•24 Slime Blocks
•18 Obsidian
•2 Sticky Piston
•11 Dispensers
•14 Redstone Dusts
•2 Redstone Torches
•1 Button
•At least 11 TNTs
Step 1: Building Shotgun Parts
Firstly, add a sticky piston onto the ground, then 12 slime blocks from the surface of the sticky piston. Next, add a line of 12 obsidian behind the slime blocks. Now add 11 dispenser on the line of obsidian starting form the end. Behind the sticky piston, leave 1 block of space and add an obsidian with a button and a redstone torch placed on it. After that, place an obsidian in a L-shape from the start of the obsidian that was placed behind the slime block, then add another redstone torch on the L-shape obsidian structure, the redstone torch should be deactivated. Add another line of 12 slime blocks starting from the top of the L-shape obsidian structure, then add another sticky piston facing the first slime block placed on the L-shape obsidian structure. Using the remaining obsidian, build a stair like structure to the dispenser from the obsidian with the button and add redstones from the button to the stairs and to the dispensers. (Refer to image given above)
Now that you've finished the parts, let's move on!
Step 2: Inserting Ammo
Thank you, for coming to my instructables! Please share this if you
think it's good and don't forget to follow me for more Minecraft (or other) builds!
Don't forget to enter my YouTube Channel: https://www.youtube.com/user/COOLCREEPER69
![Team Fortress 2 Introduction [Basics]](https://content.instructables.com/FHA/2157/IM3QJ8PT/FHA2157IM3QJ8PT.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
