Introduction: Minecraft Slime Rocket
List of things needed to build the slime rocket
- Minecraft version 1.8 or higher
- 3x Block of Iron
- 2x Normal Piston
- 3x Slime Block
- 1x Sticky Piston
- 3x Block of Redstone
Step 1: Start Building
I will let the pictures do most of the talking
First put a Block of Iron on the floor
Then put a normal piston on the block of Iron
Remove the block of Iron
Place a slime Block on the normal piston
Now build two blocks of Iron on the slime block
Remove the Iron block above the slime Block
Only one iron block,two blocks above the slime Block is left
Now put a sticky piston upside down under the block of Iron so that it's head is on the slime Block
Remove Iron block above the sticky piston and replace it with a normal piston facing upwards
Now add a Block of slime on the normal piston
The lowest slime Block must get two other slime Blocks at its side with two blocks of Redstone on top
Add another slime Block with a redstone block on top to the side of the highest slime block
If you don't understand please look at the next steps picture
Step 2: Finished
The slime rocket in action!!!
