Introduction: Minecraft Snow Modern House
My first instructable is on minecraft this is a house I made I hope you like it and build it .I'll try make more houses as soon as possible :)
Step 1: Materials for the House
The blocks you'll need are cobblestone, spruce wood(logs), snow, glass, cobblestone slabs, and cobblestone half walls
Step 2: Place Spruce Wood
Make 3 blocks tall pillers(6 in total) as showed (I used the half walls and gates to help you count the block separation the place with diamond blocks is gonna be the entrance
Step 3: Break
Break the half walls fences and diamond block(BUT remember where the entrance is
Step 4: Fill the Spaces Between the Logs With Cobble
Make sure it's only 1 block tall
Step 5: Make a "door"
In the entrance make a "door" using snow 3 blocks tall with 2 holes on the middle (bottom part)
Step 6: Make It Fancy
Put a slab in front of the entrance and put 2 cobblestone blocks beside it then top them with half walls
Step 7: New Layer
Ok time for the good part, on top of the cobblestones (aside from those on the entrance) put a 1 block layer of snow on top of all those cobbles
Step 8: Another Layer
Top that snow with some glass
Step 9: Almost Done
On top of that glass put more snow then connect that layer of snow with glass, (and also on top of the logs)
Step 10: Now the Floor
Make it whatever color you like. I'm going to make an alternative white and black pattern
Step 11: Alternate
Step 12: FURNITURE!!!!!!
I'm going to put a bed and side stands for furniture and a fridge (you can put more stuff)
Step 13: Done
That it hope you like it I'll make more houses soon
