Introduction: Minecraft Sword
Step 1: Start
To do this you need gray wool then you put an iron block into the middle but leave a hole onto the side
Step 2: Handle
To do this you need Dark oak or spruce wood then you put them in a pattern of 2 then put the original wood in the middle
Step 3: Middle End
To do this you need wool that's gray then you put it together In this pattern. You must turn to the other side.
Step 4: Rings
You'll need More gray wool then you put 2 rings on the sides like this.
Step 5: The Near End
You'll need more gray wool then you do this.
Step 6: Filling
You'll need iron blocks then you fill the Near end in with it.
Step 7: Spear
You'll need iron blocks at this height at 8 blocks.
Step 8: Finishing
You'll just go over the iron with gray wool the you're done!
