Introduction: Minecraft Teleporter
This will let you teleport in style with arrows
Step 1: Create a World
First, go click "Create a World", then change the gamemode to creative, then click create new world.
Step 2: Command Block Clock
Now, you need to give yourself a command block using this command
/give @p command_block
Step 3: Command Block Clock (continued)
Then, place a command block down and right click it.
Type in setblock ~ ~1 ~ air
After that, you place a command block 2 blocks higher than the first one and type in
fill ~ ~-1 ~ ~ ~-1 ~ redstone_block
Step 4: Command Block Clock (continued)
Now, place a redstone block in the middle and the clock will start up
Optional: if you think the text is annoying, type this command /gamerule commandBlockOutput false
Step 5: Last Command Block
Now, put a command block on a redstone block side and type this command
/execute @p ~ ~ ~ tp @p @e[type=Arrow]
Step 6: Pull, Fire!!!
Now you can try teleport anywhere you want with your complete machine.
