Introduction: Minecraft Torch Made Out of Legos
This Instructable will teach you how to make a Minecraft torch out of Legos. The reason it dosen't look like I used the same pieces, is because I ran out of legos of the right color, that weren't being used, that I could replace fast. The reason I said that, is because I didn't have a lot of time. The Legos you Need are:
6 2x2 Brown Bricks
2 2x2 Orange/Red Bricks
If you need to substitute, you can, as long as the pieces are the right color.
So, lets get started!
6 2x2 Brown Bricks
Step 1: Make the Wooden Base
So first, you have to make the wooden part of the torch, by stacking the brown bricks on top of each other, like in the picture.
Step 2: Make the Flame
Next, make the flame by stacking the orange/red bricks on top of each other, like in the picture. To make the normal torch, use orange. To make the redstone torch, use red instead of orange. You're almost done.
Step 3: Put It Together
Now, you have to put it all together. to do this, put the flame on top of the torch, like in the picture.
Step 4: Your Done!
Your done! If you did it right, if you made the normal torch, it should look like in picture 1. If you made the redstone torch, it should look like in picture 2. Like I said in the intro, If you need to substitute, you can, as long as the pieces are the right color. Thanks for reading!
