Introduction: Mini 10-Doh! Figure Custom Flash Drive
I got this guy in a Loot crate back in January, and today I'm going to show you how to put this little 10 Doh! figure to work.
Step 1: Tools and Supplies Needed.
Tools :
~ Mini Philips screwdriver
~ Utility knife
~ Hot glue gun / or super glue if hot glue is unavailable
~ USB flash drive
Step 2: Open the 10Doh! Guy.
First remove the arms and legs from the little guy, and take out the 3 small screws from the back.
Pry the case apart with a finger nail or anything thin enough to open the case without damaging it.
Step 3: Cut and Install.
Measure the bottom piece where the flash drive will be mounted and score with the utility knife then Carefully cut the plastic away to fit the flash drive into place.
Test fit the piece into your USB port you don't want the case stopping the flash drive from fully engaging.
When you have the proper placement glue it into place, you want a strong hold (movement is bad).
Step 4: All Back Tougher Now.
Now all you need to do is snap the little guy back together and put the 3 screws back in. Pop the feet and arms back on, And your done.
Thanks for checking this out if you have any questions or comments please feel free to leave them in
the comments section below, I enjoy hearing from you guys so don't be afraid to post!
